Balky passenger door
Old Aug 4, 2012 | 06:12 PM
mozz51's Avatar
mozz51
Default Balky passenger door
I'm posting here because I've found you all the most knowledgeable and helpful. The passenger door on my 05 coupe has been getting more difficult to open. The window indexes down, but I had to touch the touch pad repeatedly and in just the right spot to get the door to open. This morning it wouldn't open electrically no matter what, not even with the button inside. The driver's door works just fine.
Any suggestions on what to check or how to fix this short of going to the stealer?
Old Aug 4, 2012 | 06:35 PM
mozz51's Avatar
mozz51
Any help would be much appreciated
Old Aug 4, 2012 | 06:39 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
is this from the outside? if so
You can remove the touch pad and disassemble it to clean the contacts. It's very simple, requiring only a phillips screwdriver.
Old Aug 4, 2012 | 07:06 PM
ChevyDave's Avatar
ChevyDave
http://forums.corvetteforum.com/c6-c...-pads-too.html
Old Aug 4, 2012 | 08:27 PM
mozz51's Avatar
mozz51
Thanks for the replies. I cleaned the door pad contacts and still nothing. The pad will index the window it just won't unlatch the door. the door unlatch button on the inside doesn't work either. Any ideas?
Old Aug 4, 2012 | 08:31 PM
glenB's Avatar
glenB
Door module
Old Aug 4, 2012 | 11:37 PM
mozz51's Avatar
mozz51
What is the door module? Where is it located?
Old Aug 5, 2012 | 10:25 AM
glenB's Avatar
glenB
inside the door and controls the goings on, or it could just be the latch, you need to test.
Old Aug 5, 2012 | 10:43 PM
mozz51's Avatar
mozz51
Okay, thanks. I'll test the latch before buying any parts.
To Balky passenger door
