any ls9x install specifics??
Old Aug 5, 2012 | 12:32 PM
dvandentop's Avatar
dvandentop
Default any ls9x install specifics??
does this have to be installed or aligned any certain way???
not sure if there was weights on the flywheel like some of the other clutches i have read about.
I know that the 2nd disk needs to be put on facing the specific way though.
thanks
Old Aug 6, 2012 | 10:02 AM
Doug@WGP's Avatar
0Doug@WGP
Former Vendor
All the Ls9x kits we've done have been marked as to "flywheel" side, etc. Make sure you heat the flywheel in the over to 200deg F before installing it.
Old Aug 6, 2012 | 10:08 AM
dvandentop's Avatar
dvandentop
thanks yeah i got her installed i did heat in the oven for a while to get her up to temp as i read in some other threads.
Old Aug 6, 2012 | 10:12 AM
Doug@WGP's Avatar
0Doug@WGP
Former Vendor
Great!
Old Aug 9, 2012 | 10:16 AM
nullpointer's Avatar
nullpointer
just curious as to why you have to heat the flywheel?
Old Aug 9, 2012 | 10:19 AM
Brian@RPT's Avatar
0Brian@RPT
Former Vendor
The aluminum flywheel is a tight fit onto the crankshaft. You cannot just pull it on or you can damage it.
Old Aug 9, 2012 | 10:20 AM
Doug@WGP's Avatar
0Doug@WGP
Former Vendor
+1 what he said :-D
To any ls9x install specifics??
