Base C6 wheel alignment specs etc
Had tire wear on the outside of the front tires, rears are wearing evenly and are ok with ample tread left...I got a deal on less than 1/2 worn fronts (evenly worn and in great shape) and put them on the car yesterday...
I'm going to get a 4 wheel alignment with a very reputable local alignment shop on Friday and I wanted to get suggestions on specs...I hear Pfadt issued some specs they suggest for anything from base street driven to tracked and modded cars...
Anyone have any suggestions based on my car with the upgraded sway bars etc?
Someone near a PC may be able to help out and lost the sheet. If not, I'm sure it's on their website.
Pure Street
Front
Camber -0.8deg
Caster 8.0deg
Toe 0.0in
Rear
Camber -0.5deg
Toe 0.0in
Dual Street/Track
Front
Camber -1.2deg
Caster 5 to 8deg
Toe 0.0in
Rear
Camber -0.8deg
Toe 0.0in
Notes
For using street tires and driving to and from the track
This setting will work for R-compounds at the track
Dual Street/Track - Aggressive
Front
Camber -1.6deg
Caster 5 to 8deg
Toe 0.0in
Rear
Camber -1.1deg
Toe - 1/8in
Notes
For using R-compound tires, and minimal street driving.
This setting will cause wear on the inside edges of street tires
Dedicated Track Car
Front
Camber -2.5deg or more depending on testing
Caster 3 to 6deg
Toe 0.0in possibly some toe out
Rear
Camber -1.9deg or maximum even settings
Toe 0.0in try a little toe in to settle the rear
Notes
Race tires, DOT or slicks
There is no substitute for testing!
Camber Alignment Settings
