I pod
Old Aug 8, 2012 | 08:56 AM
judson whitley's Avatar
judson whitley
Default I pod
Have 2010 with IPOD cable in glove compartment I have the PAL first edition manual with this does this mean i can just connect the IPOD and it will be ready to go or do i need additional cables etc, thanks
Old Aug 13, 2012 | 07:07 PM
pmt67usa's Avatar
pmt67usa
Veteran: National Guard
It sounds like your car has the first generation GM PAL. You can verify by looking under the passenger carpet to the left of the fuse box. If it is installed correctly, simply connect an IPOD, select XM2 on the radio and it should play perfectly. The best bet on the forum regarding all the IPOD interfaces is Ray Kawal...he was invaluable in diagnosing the incorrect installation on my 2009. Got it working...perfect. His website is http://www.kawal.net
Good luck....this is a great mod to the vette...
Pat
