Steering Column Lock Module - DIY? 2005
http://www.youtube.com/watch?v=umBo8Q3PF6A
IF YOUR TEARING THE DASH APART NOW IS A GOOD TIME TO INSTALL THE COLUMN LOCK ELIMINATOR.
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
However, I've had my instrument cluster out several times for different reasons, and I still find it difficult to get that wire harness connector unclipped from the HUD button pod. I find it much easier to use a stubby philips head screwdriver to remove the 3 screws that hold the button pod in the trim bezel, then you can easily see the connector to release it.
You still have to remove the interior light connector by feel, but that's easy.
When reinstalling, just screw the pod back in, then when you're ready it's very easy to plug the connector back in by feel.
Here's a picture of doing a similar thing on the right side, which you won't need to remove when installing the Column Lock Eliminator, but it shows the location of the 3 screws:
COHPARTS, thanks for a product that will cut down on a lot of
and
when the column lock won't release!!My b-in-law hasn't had problems with it, but after all the problems in the C5 and the fact that many '05 C6 owners are starting to experience problems, I got him the Eliminator to make sure he'll never have to deal with the problem!!!
Bob
That had been clearly spelled out by the DIY pioneers in the HUD removal/installation procedure!
and
Bob
GLAD YOU GOT IT PUT TO TOGETHER AND GOING AGAIN WITH NO WORRIES.
THANKS FOR YOUR PURCHASE
Of course, I didn't get a warranty with the Corvette either so I'm not losing any sleep on either.
