(C6 Diff/trans Failures) Please post your experience, I've got some fix options......
I'm interested to see if there have been any 30 spline mainshaft failures in the T56 or TR6060's(Z06/Grandsport/ZR1.....6060 was introduced in 2008)
Some quick notes on C6 trans/diff progression:
>>Manual Transmission
NOTE: ALL 2008 up C6's use the TR6060(although different versions(ie: 27/30 spline/ratio's/gear material/etc.)
NOTE: different gear ratio's used (base/Z51/GS/Z06/ZR1)
1a. 2005 manual/auto C6's used the older "C5 style" 5 bolt tailhousing, although the diff sidecovers used the C6 style mounts(2 mounts fwd of axle vs. 1 center mount below diff case on C5)
1. ALL base manual C6's rec'd 27spline trans mainshafts
2. ALL Z06/Grandsport/ZR1 manual C6's rec'd 30 spline mainshafts
2a. ZR1 also used 4615 steel for the gears/shafts(see "blownblueZ06's post in C5 FI for details)
http://forums.corvetteforum.com/c5-f...ous-power.html
3. ALL 2006up A6's rec'd 30 spline mainshafts
4. The 27 or 30 spline transmission mainshaft will coincide with the differential(pinion gear)
[B][I][SIZE="3"][COLOR="Blue"]
>>Automatic Transmission
1. 2005 was the ONE year to use the 4spd 4L60, 27 spline output??
2. 2006up used the A6, 30 spline output
>>Differential
1. 2005's, again the oddball C6 diff, 5 bolt trans/diff interface, 2005 diff's seem to crack often in the aft/lower center casting. ALL 2005 diff's use 27 spline pinion gears.
2. ALL 2006-2013 A6 diff's use 30 spline pinion gears.
2. 2006 was the first year of the "8 bolt trans/diff interface
3. 2006-2013 Z06's rec'd a unique case and bigger ring/pinion than the base cars. ALL Z06 diff's are 30spline
4. 2010-2013 Grandsport, I am not aware of any changes from the GS from the Z06 diff.
5. 2009-2013 ZR1, sitting on the 3rd shelf if you will, the massive ribs on the ZR1 castings set it apart from it's C6 base and Z06 siblings from 10 feet away, if you have any info on internal changes of the ZR1 vs. the Z06, please share
6. 2009 there was a change to the Torque Tube, I have not verified if this was only on the ZR1 are across the board on C6 production. ZR1 used a different heat exchanger for the diff (Thanks Rodney@RPM for the info)
Below is a pic of a 2005 diff I recently replaced(2012 ZR1 trans with 2012 Z06 diff was the replacement)
The diff cracked near the bottom of the case into the aft cover area
I hope it lives...........
Have had some odd shifting issues at the track, but never before on the street.
