Emission test incomplete without Error code
Old Aug 16, 2012 | 11:10 PM
SMJBA's Avatar
SMJBA
Default Emission test incomplete without Error code
Can anyone clue me on what the issue is. There is no trouble code stored however the emission status light is amber on my scan tool. Car runs fine and has only 3,000 miles
2006 LS2
Test report: Mode $06 report generated by Torque for Android
MID:$01 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
Test incomplete or dependant test failed
MID:$01 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 1 Sensor 1
MID:$01 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.2501V Min: 0.2501V
Test result value: 0.2501V
PASS
MID:$01 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 1 Sensor 1
Max: 0.62537V Min: 0.62537V
Test result value: 0.62537V
PASS
MID:$01 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 1
MID:$01 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 1 Sensor 1
MID:$01 TID:$80
MID:$02 TID:$8a
- O2 Bank 1 Sensor 2
Max: 1,450Count Min: 0Count
Test result value: 1Count
PASS
MID:$02 TID:$8b
Max: 1.07494V Min: 0.69381V
Test result value: 0.69418V
PASS
MID:$02 TID:$8c
Max: 0.34099V Min: 0V
Test result value: 0.18642V
PASS
MID:$05 TID:$01
Rich to Lean sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
MID:$05 TID:$02
Lean to Rich sensor threshold voltage(constant) - O2 Bank 2 Sensor 1
MID:$05 TID:$03
Low sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$04
High sensor Voltage for switch time calculation - O2 Bank 2 Sensor 1
PASS
MID:$05 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 2 Sensor 1
MID:$05 TID:$06
Lean to Rich sensor switch time(calculated) - O2 Bank 2 Sensor 1
MID:$05 TID:$80
MID:$06 TID:$8a
- O2 Bank 2 Sensor 2
Test result value: 302Count
PASS
MID:$06 TID:$8b
Test result value: 0.7037V
PASS
MID:$06 TID:$8c
Test result value: 0.10394V
PASS
MID:$21 TID:$a0
- Catalyst Monitor Bank 1
Max: 144ms Min: -25,000ms
Test result value: -628ms
PASS
MID:$22 TID:$a0
- Catalyst Monitor Bank 2
Max: 142ms Min: -25,000ms
PASS
MID:$3a TID:$c0
- EVAP Monitor (cap off)
MID:$3a TID:$c1
MID:$3c TID:$c8
- EVAP Monitor (0.040")
MID:$3c TID:$c9
MID:$3c TID:$ca
MID:$3c TID:$cb
MID:$3d TID:$c4
- EVAP Monitor (0.020")
Max: 6,553.5S Min: 60S
Test result value: 60S
PASS
MID:$3d TID:$c5
Max: 2,500Pa Min: -8,000Pa
Test result value: -8.25Pa
PASS
MID:$3d TID:$c6
MID:$3d TID:$c7
MID:$41 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 8Count Min: 0Count
Test result value: 0Count
PASS
MID:$41 TID:$d3
Max: 2.481 Min: -4.211
Test result value: -0.084
PASS
MID:$42 TID:$d2
- O2 Heater Monitor Bank 1 - Sensor 2
PASS
MID:$42 TID:$d3
Max: 4.571 Min: -7.5
Test result value: -0.505
PASS
MID:$45 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 1
PASS
MID:$45 TID:$d3
Test result value: -0.464
PASS
MID:$46 TID:$d2
- O2 Heater Monitor Bank 2 - Sensor 2
PASS
MID:$46 TID:$d3
Test result value: -1.634
PASS
MID:$61 TID:$40
- Heated Catalyst Monitor Bank 1
Max: 0 Min: 20,561
Test result value: 16,480
FAIL
MID:$81 TID:$63
- Fuel System Monitor Bank 1
Max: 41,013 Min: 26,816
Test result value: 9,904
FAIL
MID:$a1 TID:$63
- Misfire Monitor General Data
Max: 41,055 Min: 10,432
FAIL
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
MID:$a6 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 5 Data
PASS
MID:$a6 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 5 Data
PASS
MID:$a7 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 6 Data
PASS
MID:$a7 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 6 Data
PASS
MID:$a8 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 7 Data
PASS
MID:$a8 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 7 Data
PASS
MID:$a9 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 8 Data
PASS
MID:$a9 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 8 Data
PASS
MID:$f8 TID:$30
Manufacturer defined MID -
Max: 409.60001 Min: 5,641.7002
Test result value: 2,893.1001
FAIL
Old Aug 17, 2012 | 12:50 AM
ChevyDave's Avatar
ChevyDave
added: 3000 miles in 6 years, when did you get fresh gas last? just a thought, probably nothing. my understanding is that, your MID/TID codes that show 'fail', mean they are failing but not yet enough to cause a check engine light.
Not Ready or Suspended would refer to a 'drive cycle' not yet completed. that doesnt seem to be the case. Incomplete or dependant would mean another 'fail' must pass first. what i found were these..
MID:$61 TID:$40
Max: 0 Min: 20,561
FAIL
MID:$81 TID:$63
FAIL
MID:$a1 TID:$63
FAIL
go to dealership or try....
1) disconnect negative battery cable for few minutes and reconnect. some errors wait until X restarts/cycles to clear and will reset with battery cable remove. (you will have to reindex windows)
2) do this shortened drive cycle.. http://www.obdii.com/drivecycle.html
3) get codes read if check engine light on at any time
4) get another inspection to see if less/any FAILS
if you want to fall asleep reading (gotta be good stuff in here, my eyes glaze over before i get far)..
http://webtools.delmarlearning.com/s...12203_Ch03.pdf
and if your still awake and want to reach coma stage... http://d-tips.com/general/articles/article.aspx?id=5
Last edited by ChevyDave; Aug 17, 2012 at 01:36 AM. Reason: added first line comment
