Understanding DA and it's effect on ET/MPH
Density Altitude (DA) has a big effect on your engine's ability to produce HP, which obviously has a big impact on not only drag racing trap speed, but also ET.
DA is your actual track altitude adjusted for temperature, baro pressure and to a lessor degree; humidity.
Here is a good calculator to find your current DA:
http://www.dragtimes.com/da-density-...calculator.php
You need to know:
1. The actual elevation of the track (feet above sea level)
2. The barometric pressure at the time
3. The current ambient air temp at the time
4. And the humidity
Example ...
Track Elevation
1,200 feet above sea level
Baro Pressure:
29.87" Hg
Temp:
90 Degrees F
Humidity:
65%
These conditions = DA of 3,899 feet
Not good ... You are racing at a track that is only 1,200' above sea level, but your engine will perform the same as if you were racing at a track 3,899' above sea level on a SAE / NASA "Standard Day". What is a "Standard" SAE / NASA day ... It's a day where the Barometric Pressure is 29.92" Hg, Temp of 59 Degrees F, and 0% Humidity.
Don't remember the condition at the track when you raced last? ... No problem ... At the top of the calculator you can enter the track name and date you ran. It will give you all the info you need to determine what the DA was at various times of the day. Even tells you the altitude of the track above sea level.
Now ... This is good info, but what if you want to know how well your car would run if it were at sea level track on a SAE / NASA "Standard Day".
Again, the DA was 3,899' in our example above. On the bottom of the calculator, you can enter that 3,899' and your ET of lets say 12.50, and your MPH of 115.00
At a sea level track, on a normal SEA Standard day (Sea Level, 29.92" Hg, 59 Degrees F, and 0% humidity), your car would have run 11.90 @ 119.20 ET.
That is now your "Corrected" ET and MPH .... Akin to "Corrected HP" that can be found on dyno sheets ... Just standardizes everything to one condition.
That's All Folks!
School is Out!
You need to know:
4. And the humidity
Example ...
Track Elevation
Baro Pressure:
29.87" Hg
Temp:
90 Degrees F
Humidity:
65%
At a sea level track, on a normal SEA Standard day (Sea Level, 29.92" Hg, 59 Degrees F, and 0% humidity), your car COULD HAVE run 11.90 @ 119.20 ET.
That's All Folks!
School is Out!
Just my $0.02.
I like your RWHP paper racing analogy.
The info provided on Dragtimes (or most online sites) is not often gathered directly from the actual track itself (could be from 4 stories up at a nearby airport, could be from the 3rd floor of an office building 10 miles away) where you're racing at. And even if their weather reading equipment is right at the track it's likely not taken right from the actual starting at bumper level.
In other words, those Dragtimes calculations might get you close to the actual DA of when/where you ran, but it's certainly not exact.
The only way to know the exact weather conditions/DA is with a working, accurate hand held weather station used to calculate the various factors right at the line and near the ground/bumper height.
I wrote this basically just to help some of our members here that may not know much about DA except to say that high temps and high altitudes hurt power.
To be honest ... just something I wrote when a little bored today, but hey ... maybe someone might get some a little insight out of it nontheless.
Ron,
_______________________________
COULD HAVE ...... Good point!
Now you can log every run and the exact conditions it was made under... I have had 6 ...yes SIX of these TAG weather stations, and I think they are the best thing since sliced bread...
The reason I have had 6 is because I'd put it on my tire (in the shade) and forget it and run over it... or after I got smart I'd lay it on the ground BEHIND the wheel so if I did drive I wouldn't run over it...
nope.. the car in-front of me wouldn't start in the lanes, so I BACKED UP OVER MY 4th TAG
...I think Ralph made his own TAG from all my crushed parts... The bad news is TAG went out of business about 2 yrs ago... and I can't get mine replaced or fixed if anything should happen to it...
I now have learned to TAKE CARE OF IT.. and not let my "Advanced Age" hinder my taking care of my "LAST" TAG....
