Not my vette, asking for a friend, but it got struck by lightning. has absolutely no power. Wiring is not melted or anything. Does all the computers need to be changed , etc...or is all wiring and electrical shot? Thanks
Could be just one thing or a bunch of things. His comprehensive insurance should cover it. Hopefully, he had a low deductible on the comp. Best thing to do is to take it to a dealer and let them figure it all out as they have the tools to talk to all the modules on the car. Despite the wiring not being melted the bolt could have generated a huge pulse of electricity in the modules. Since they can only take about 5V on their input lines a number of them could have been electrically overstressed.
ive done a few.most of time pcm and bcm are toast.sdm module too.you need a tech 2 to find which modules are not comunicating.and remember one module that is shorted can knock out others,you need to have someone that knows what they are doing ,because those modules are not cheap and non refundable. good luck
These car's electrical systems/computers are so complex, that even if it could be fixed, I would drive it from the service area around front and trade it in on a new one. I think it would be as bad as a flood car.
Boy, that's not a DIY project. No telling what got fried. Keep us informed as to the outcome.
y'all need better friends or contacts
I've been friends with the Curlee family(Bill and Cheryl) here in CT for almost 10 years, I also have the Snap-On Solis and GM Tech2 and an outstanding network of GM techs to rely upon.
OP'er, start with the "Physical" inspection, this is where a lot of the electrical problems can be traced
I'm surprised the lightning would get into the electrical since most of the car is plastic or fiberglass.
Lightning, like any electricity, takes the path of least resistance.
On a steel car, most of it will go through the body and frame.
Since the "plastic" body of the C6 doesn't conduct very well, that leaves the frame and all dem little wires running around inside the car. Might work pretty well, or not.
The bigger question for me, is what happens to people who are in the Corvette when it gets hit? Might be fine, or not...
Friend of mine was struck by lightning in his chevy van last week, it blew out the rear tire and fried the electrical system, most likely they will total it. Lightning is no joke, lots of bad strikes this year.
The inductive field surrounding a lightning strike will create electrical current flow in anything metal close by. A direct hit causing conductive flow is not necessary. Years ago, I had a close strike induce a strong overload in my house wiring blowing out circuit breakers. The same thing can happen in our Vettes regardless of the composite body.
Having worked with and been to a place called Copart Auctions there are a lot of totaled cars there due to lightning they say if it is hit hard enough that pretty much every module has to be replaced at the same time for instance a Cadillac 2008 CTS its total was at $13,000 but in labor and 4 computers and 138 module components it was more like $15,000 totally not worth it .let them total it unless there was no insurance. Even window motors have modules in them .
