Basic question on compression test
Old Aug 18, 2012 | 02:23 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Default Basic question on compression test
Ok, real basic question. I feel dumb having to ask it, but here goes.
I understand the basics of doing a compression test. You pull all the plugs, screw the gauge into each plug hole, crank the engine, read the results, right?
But how do you keep the coils from firing? Or maybe you don't Do you just let the plug wires dangle? I want to make sure I don't damage anything.
Old Aug 18, 2012 | 02:31 PM
KB9GKC's Avatar
KB9GKC
Hello,
It's better to ask a dumb question than make a dumb mistake!
I would not allow the plug wires to bounce around and arc because it's just not good policy. You could get a shock, or the arc could be an ignition source for a fire.
With that sad I would unplug the ignition wire from the spark plug and unplug the ignition wire from the coil.
All your readings should be within 10% or less highest to lowest compression reading.
Good Luck,
Douglas in Green Bay
Old Aug 18, 2012 | 04:33 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Thanks for the reply!
Also, since our cars have pushbutton start, how do you turn the engine over? Do you just let it crank until the start algorithm "gives up"?
Old Aug 18, 2012 | 08:33 PM
madmax4499's Avatar
madmax4499
thats a good question, I would short the starter relay to make it crank. this would also not allow the coils to fire. I would also hold open the throttle body if it were me.
post up the numbers when you are done! also why are you doing one?
Old Aug 21, 2012 | 01:12 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My understanding is that a "leakdown" test with compressed air is more difficult to do, but may provide more accurate information.
Depends on what you are trying to discover.
Old Aug 22, 2012 | 06:50 AM
Gannet's Avatar
Gannet
St. Jude Donor '06
Thanks for the replies so far.
Anybody else? C'mon, many of you must have done one of these on a C6 before.
Old Aug 22, 2012 | 09:49 AM
madmax4499's Avatar
madmax4499
what else are you looking for? un plug the coil pack the center big white plug on each side. for cranking push the start button, when the gauge stops moving up push the bottom of the start button and it will stop cranking.
Old Aug 22, 2012 | 03:11 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
As mentioned unplug the coil packs at the middle big plug, on both sides. But I would also add removing the fuel pump relay as you don't want the cylinders to get any fuel and skew the results as you continue to crank. Screw in the tester one cylinder at a time and hit the starter button. It will crank and crank. Stop when you see the gauge not moving any higher, about 4-5 seconds.
Old Aug 22, 2012 | 09:07 PM
Gannet's Avatar
Gannet
St. Jude Donor '06
Originally Posted by madmax4499
... push the bottom of the start button and it will stop cranking.
This is the part I didn't know, thank you.
Old Aug 22, 2012 | 10:29 PM
Legal Alien's Avatar
Legal Alien
It was always my understanding that a compression test should be done with the engine at full working temperature?
Old Aug 23, 2012 | 05:52 AM
AIR_RAM's Avatar
AIR_RAM
Pull the fuse to both the fuel and ignition system. This will remove any spark or fuel from the equation.
You also want to be holding the throttle body WOT while your turning it over... You want zero restrictions.
Also you want to make sure all spark plugs have been removed.
Doing this after the engine has fully warmed up is not completely necessary but can give higher readings. But its the difference between each cylinder that your most concerned with.
SPEED SAFE, NICK
Old Aug 24, 2012 | 11:32 AM
Kerrdogg's Avatar
Kerrdogg
SPEED SAFE, NICK
Pretty much it, I have always done the test with a semi warm engine, only takes a few seconds per cylinder, I would have a helper sit at the controls, with pen and paper.
Oh one final tip make sure the schrader valve is installed in the air hose, some people take them out to pressurize the cylinders to change valve springs, ect, without it all you'll get is Phffft, phffft, phfft .
To Basic question on compression test
