Mild to Wild mod question
I bought a rocker switch and it has a power / acc /ground plugs . I know the wire going from the add-a-circuit goes to the power plug on the switch.
I take it the other wire you have to add goes to the ground plug on the switch ? I'm fairly certain on it..just want to make sure.
I was giong to do the way that has the add-a-circuit plugged into the seat heater then the other wire down in the NPP circuit. I take it the seat heater way is to prevent battery drain ????
