The current LSA crate motor is the cadillac cts-v version. On sale for just over $11k. Now the Camaro ZL1 is coming out with the exact same motor with a slightly larger supercharger. This motor is rated at 580hp. When is this coming to the crate engine market? I understand they thru out the titanium parts from the LS-9 motor and sodium filled valves and replaced with forged steel to keep the price down. The block is a LS-9 block and not a LS3. The LSA 556hp is a great motor for the price, but I would like to hold out for the LSA 580hp version.
Any news?
Looks like the CTS-V LSA is 9:0 compression and the ZL1 LSA is 9:1 compression.
Do you actually mean 9.0:1 versus 9.1:1?
I don't think one can have a x:0 compression ratio?
Originally Posted by tdishon
Also the supercharger is more efficient.
Both producing 9lbs of boost.
Interesting thing though, The ZL1 LSA is only rated to 6200 rpm and the CTS-V LSA is rated to 6600 rpm????
I'd really thought (assumed) that the two engines (ie: the CTS-V's LSA and the ZL1's LSA) were identical engines with just slightly different power ratings due to slight exhaust system and 'factory tuning/programming' differences. But maybe not.
