More power top ???
Old Aug 30, 2012 | 02:46 PM
windyC6's Avatar
windyC6
Default More power top ???
Thanks for your responses on the pump fluid. Now maybe someone has had this same problem and knows a fix. The power top "up" cycle is....taneau (sp) cover opens....top goes 1/2 way up...taneau closes....top closes the rest of the way. The problem is that the taneau cover is not closing the last 1/2 inch or so, and when the taneau cover doesn't close all the way, the cycle won't finish. After going through the cycle once or twice it will usuall close, but I can only see this getting worse. Anyone had this problem and gotten lucky with a fix ????
