I was surprised!
Old Sep 1, 2012 | 11:30 AM
ROD BROWN's Avatar
ROD BROWN
Default I was surprised!
Hi,guys, I got off of my lazy rump and decided to do something for a change.Well,I lift up the hood on my 09 Vette(second or third time since I owned the car) and i cleaned the throttle body.Well,I was surprised,it made that car run so much better.The car accelerates better and idles much smoother.It was 1 hour of maintenance that was well worth the time.Back to the couch.Rod
Old Sep 1, 2012 | 12:01 PM
Deftly's Avatar
Deftly
Sitting on the couch myself I have to ask. What do you do to clean a throttle body?
Old Sep 1, 2012 | 12:21 PM
ROD BROWN's Avatar
ROD BROWN
Default Cleaning the throttle body
Hi,I went down to the parts house about 2 years ago and bought a can of throttle body cleaner.I removed the air cleaner and sprayed fhe cleaner into the throttle body while I the car idled for about 2 or 3 minutes. Then I used a CLEAN rag to clean the interior of the throttle body.Finished by wiping the out side of the throttle body.Really is easy.I followed the instructions on the can.Well worth the time. Rod
Old Sep 1, 2012 | 01:47 PM
carpe dm's Avatar
carpe dm
I did this to a C5 some years ago, but haven't done the C6 yet. Good job!
Old Sep 1, 2012 | 01:56 PM
ROD BROWN's Avatar
ROD BROWN
Default Every 6 months
Thank you,I am going to do this every 6 months as the time to do this is worth the results.Rod:flag :
Old Sep 1, 2012 | 07:30 PM
crusher1's Avatar
crusher1
I clean my throttle body every Spring..Easy maintenence and the car does idle smoother and acceleration feels snapper after doing it
Old Sep 1, 2012 | 07:35 PM
Cyberwar's Avatar
Cyberwar
So would cleaning the throttle body be that necessary and make that much performance difference if you had a catch can installed inline to catch the oil residue?
Old Sep 1, 2012 | 10:24 PM
stevebz06's Avatar
stevebz06
I think all cars benefit from this whether they are oil burners or not.
Old Sep 2, 2012 | 04:16 PM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Placebo effect. Mine is much faster after I wash it.
Old Sep 2, 2012 | 06:01 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Catch can collects oil vapor from the valley cover that would otherwise be sent to the intake manifold behind the throttle body by the PCV system. It has no effect on the throttle body, but instead prevents fouling the interior of the intake manifold and contributing to carbon buildup on pistons.
Old Sep 2, 2012 | 06:05 PM
zwaldo's Avatar
zwaldo
it is technically only if you wax it :P
Old Sep 2, 2012 | 08:16 PM
S'vette's Avatar
S'vette
I use the MAF cleaner every month on my MAF when I clean my intake filter and I wipe down the throttle body inside as it can get a little dirty but not much really, mainly just at the pivotinf points.
Old Sep 2, 2012 | 08:17 PM
S'vette's Avatar
S'vette
Or the Zaino works. Ive done a before and after dyno and it showed me faster after the Zaino works was done.
Old Sep 3, 2012 | 09:52 PM
VET4LES's Avatar
VET4LES
I clean mine every year or so. I can't tell any difference in the way it runs but it makes me feel better knowing it's clean.
Old Sep 11, 2012 | 08:43 PM
Upper_Decker's Avatar
Upper_Decker
So can the MAF cleaner be used on the throttle body too? Does it matter if the cleaner (MAF or TB) gets into the engine while it's running?
Old Sep 11, 2012 | 09:41 PM
Thomasmoto's Avatar
Thomasmoto
First you have to get off the couch.
Old Sep 11, 2012 | 10:24 PM
S'vette's Avatar
S'vette
either is fine, I just use the MAF cleaner cuz I use it on the MAF sensor wire every time I clean my filter.
To I was surprised!
