Engine and Diff Mounts
Old Sep 2, 2012 | 05:31 PM
timd38's Avatar
timd38
Default Engine and Diff Mounts
If you replace the diff mounts with, lets Pfadt ones, do you need to change the engine mounts to the same type as well?
I asked becasue I was told that if you don't and one is stiffer than the other, that it will put strain on the driveline becasue one end is stiffer than the other.
Old Sep 2, 2012 | 11:48 PM
taken19's Avatar
taken19
Track Junky
I don't know if I did it wrong, but I replaced engine mounts with Hinson poly ones and left the stock tranny mounts in. I figure that the stiffer engine mounts will keep the driveline more stable and the tranny mounts will still absorb and excess vibration.
Old Sep 3, 2012 | 12:38 AM
SpecialSause's Avatar
SpecialSause
Thats what I did. Poly mounts up front because the stock engine mounts are horrible and stock ones in the back to absorb shock from launching it.
I wouldn't mix and match the pfadt ones though.
Old Sep 3, 2012 | 07:01 AM
timd38's Avatar
timd38
Thanks!
I was thinking just the opposite. Stiff in the rear to stabilize the driveline and soft in the front to not make the car shake at idle becasue of the cam.
To Engine and Diff Mounts
