found two leaks
Old Sep 3, 2012 | 09:32 PM
smitty9468's Avatar
smitty9468
Default found two leaks
I have an 07 w/ 28700miles. I've found an oil leak on the bottom right of the oil pan and tyranny leak on the same side. Is this common for these vehicles? I never seen any spots on my garage floor.
Old Sep 4, 2012 | 05:03 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
My 06 with 37K miles has no leaks, so I can't say that is common.
Old Sep 4, 2012 | 06:26 PM
ricknyc23's Avatar
ricknyc23
oil pan leaks are very common. I had mine replaced on my 07 at the end of the power train warranty period
Old Sep 5, 2012 | 10:37 PM
USAF-Vette's Avatar
USAF-Vette
What up, thundercat?!
Old Sep 6, 2012 | 12:54 PM
FireRoc's Avatar
FireRoc
Is it a tranny leak for sure, or could it be differential. It is somewhat common for the half shafts seals to leak. I've had to replace both sides on my 2005.
Old Sep 6, 2012 | 05:33 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Smitty9468,
I'm sorry you have an oil pan and tyranny leak. Have you taken your Corvette to your local Chevy dealership to have this issue addressed?
Evan, Chevrolet Customer Service
Old Sep 6, 2012 | 10:07 PM
smitty9468's Avatar
smitty9468
Originally Posted by Chevy Cust Svc
Smitty9468,
I'm taken it into the local dealership tomorrow
Old Sep 8, 2012 | 05:36 PM
smitty9468's Avatar
smitty9468
Just dropped off the Bette at the dealership. Hope it doesn't cost me an arm and a leg.
Old Sep 8, 2012 | 05:38 PM
smitty9468's Avatar
smitty9468
Vette
Old Sep 8, 2012 | 05:56 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
Good Luck. Let us know the outcome.
Old Sep 8, 2012 | 06:13 PM
Keith Tedford's Avatar
Keith Tedford
If you are lucky, it might be just a matter of snugging up bolts. Better to check them first than to tear the whole thing apart for no good reason. I always try the simple stuff first. Some times you get lucky. Our 2005 is dry as can be. Knock on wood.
Old Sep 8, 2012 | 07:36 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
That's true. I snugged up mine a couple of years ago and my 06 is dry. Unfortunately you can't reach all the bolts, but I snugged what I could.
Old Sep 10, 2012 | 10:19 AM
Red89gt's Avatar
Red89gt
Any updates on your car?
Mine going in tomorrow to have wet oil pan looked at as well.
Old Sep 10, 2012 | 08:47 PM
smitty9468's Avatar
smitty9468
Got it back today from the dealership. They stated, no leaks but I was in need of a break job.
Old Sep 11, 2012 | 06:01 PM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
So where did they say the oil you saw came from?
Old Sep 11, 2012 | 08:10 PM
Red89gt's Avatar
Red89gt
Dropped mine off for same thing to dealer tonight. They took good care of the car and kept it inside last time when it needed a front wheel bearing.
Hope they pin poin and repair and not clean and add die and ask me to come back. Got to do what you need to I guess, going to just roll with it.
Old Sep 11, 2012 | 08:59 PM
smitty9468's Avatar
smitty9468
They said the leak came from the oil filter
Old Sep 11, 2012 | 10:01 PM
Red89gt's Avatar
Red89gt
Mine is wet on the front corner and 2 other spots.
Glad yours was easy and I hope that is all it was.
Old Sep 12, 2012 | 02:55 PM
Red89gt's Avatar
Red89gt
Dealer called me back already, changing the pan gasket, confirmed oil pan leak.
To found two leaks
