c6 base brake upgrade??
Old Sep 4, 2012 | 07:33 PM
pnap88's Avatar
pnap88
Default c6 base brake upgrade??
i am wondering what upgrade can fit onto thr stock c6 base model year 2013. i am wondering what changes to the brake system i can do while maintaining the stock rims 18/19 ??
Old Sep 4, 2012 | 07:35 PM
TRBOKEV's Avatar
TRBOKEV
Just change the pads.
timd38's Avatar
timd38
Wilwood brakes will work with a small spacer.
Old Sep 4, 2012 | 07:47 PM
pnap88's Avatar
pnap88
What do you have to change with the wildwood. And have you done this?? Do you know the spacer size?
Old Sep 4, 2012 | 07:48 PM
RicK T's Avatar
RicK T
When you say "upgrade", do you mean a cosmetic upgrade?....or performance upgrade for some kind of track use, ie: auto-X, HPDE, or actual track?
Does your car already have the optional J55 brakes?
Old Sep 4, 2012 | 08:10 PM
timd38's Avatar
timd38
1/4" spacer. I have BBS wheels for the street and factory wheels for the track.
Old Sep 4, 2012 | 08:23 PM
pnap88's Avatar
pnap88
Does your car already have the optional J55 brake option?
performance, i dont believe i have the j55 option, if that is the Cross-drilled brake rotors 500 option when you build your car than no i dont have them, i do have different looking calipers than the 2012 model because mine is the 60th anniversary addition i am assuming?? unless it is just show?
Old Sep 4, 2012 | 08:25 PM
pnap88's Avatar
pnap88
do you happen to remember or know the list of prts numbers you used for the front and back, possibly any links or sites, maybe prices if im not going to far!!!
Old Sep 4, 2012 | 08:30 PM
timd38's Avatar
timd38
http://wilwood.com/BrakeKits/BrakeKi...ion=C-6&whl=18
05 to 13 are all the same brakes.
Forged Narrow Superlite 6R Big Brake Front Brake Kit (Hat), Forged Narrow Superlite 4R Big Brake Rear Brake Kit For OE Parking Brake is the one you want.
Old Sep 4, 2012 | 08:35 PM
Nyvetteguy007's Avatar
Nyvetteguy007
I recently did Powerstop Drilled and Slotted rotors with their Ceramic Pads and LOVE the results
No spacers or anything needed...fit right on....no dust and no squeak
You can get them from Brakemotive:
http://forums.corvetteforum.com/c6-c...ices-ever.html
Old Sep 4, 2012 | 10:10 PM
pnap88's Avatar
pnap88
i see you are close to me as i am in westchester as well, i am a 2013, what was your cost and what parts are included.??
Old Sep 4, 2012 | 10:22 PM
pnap88's Avatar
pnap88
i just looked at the links and see that the wilwood will run 4000 basically.
Old Sep 5, 2012 | 03:14 PM
Flame Red's Avatar
Flame Red
I bought a used set of Z51 brackets and a set of Z51 DBA rotors. They are a nice upgrades for the price. Uses the stock base calipers and new set of Akebono ACT731 ProACT Ultra-Premium Ceramic Brake Pad.
Added a set of stainless braided brake lines. Just be aware that a number of us ran into big problems with the right rear line nut!
I needed new rotors (old ones scored) and new pads (could not stand the squealing crapulant GM pads). Ken @ KNS Brakes got me the deal of the century on a set of Z51 DBA rotors at a steep discount. He is the man if you need anything dealing with Vette brakes.
Old Sep 5, 2012 | 03:37 PM
dbratten's Avatar
dbratten
You say you're after a performance upgrade. Z51 rotors will not give you this. Ceramic pads will give you LESS braking along with less dust. If you want relatively inexpensive better braking you need to improve the pads. You will have more dust. That is the trade off.
I prefer the Carbotech XP pads for track and autox and run them on the street most of the time. They do squeal if you don't keep them bedded. And, they are dusty but they really stop. The Carbotech 1521 pads are a good choice for street and are compatable with their XP pads.
Old Sep 5, 2012 | 04:09 PM
Carbotech Adam's Avatar
Carbotech Adam
Supporting Vendor
St. Jude Donor '11,'13
They are the same caliper as all base models. I would look at the Carbotech XP8 for street and tack use all in one.
A high torque brake compound with a wide operating temperature range of 200°F-1350°F+ (93°C to 732°C+). Carbotech™ XP8™ is the first of our racing compounds. Good initial bite at race temperatures, high coefficient of friction, excellent modulation and release characteristics. Extremely high fade resistance and very rotor friendly. Excellent as a front brake pad for lighter applications weighing around 2,400lbs or less. Perfect for track day use with any tire and can still be driven safely to and from the track. Carbotech™ does NOT recommended XP8™ as a daily driven street pad due to elevated levels of dust and noise. Carbotech™ XP8™ is a great compound on the front & rear of most open wheel and sports racers.
__________________
Adam Adelstein
Email: adam@ctbrakes.com
Web: Carbotech – CT Brakes
Old Sep 5, 2012 | 08:03 PM
pnap88's Avatar
pnap88
with all of this information i am overwhelmed and finding it hard to make a decision. i am more confused now than ever before.
Old Sep 15, 2012 | 09:14 PM
michaelmyers's Avatar
michaelmyers
Where did you pick up the brackets from and how much? Thanks
Old Sep 15, 2012 | 09:29 PM
oldmansan's Avatar
oldmansan
St. Jude Donor '09
Because your intial post is vague at best.
What is it you want? Do want a big brake kit? Do you want more aggressive braking but more dust? Do you want to upgrade the pads? Do you want to upgrade the rotors? Do you know anything about brakes at all?
San
To c6 base brake upgrade??
