First time to track tonight, any tips.
Old Sep 17, 2012 | 09:30 AM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by BELLMAN
I'm having trouble with my photobucket uploading so I'll break it down:
Here is the best pass. not sure what to think of the 60', i couldn't duplicate it. but the balance of the run is also quicker ?????
60' 1.6390
330 4.8242
594' 6.9049
1/8 7.3732
1/8mph 96.10
1/4et 11.4271
1/4mph 118.34
My other passes looked more like this:
60' 1.9132
330 5.0528
594 7.1222
1/8 7.5918
1/8mph 95.80
1/4et 11.594
1/4mph 119.04
let's disect this turd. not impressed with it for 560 rwhp.
Thats a great 60 time. I can only get slightly better on drag radials. You are losing a lot to the 8th though. I would guess your spinning somewhere after the launch.
Old Sep 17, 2012 | 09:55 AM
BELLMAN's Avatar
BELLMAN
it was spinning some at the top of first gear and some in second. just feel the 1/4 mph should be quite a bit higher regardless ????
Old Sep 17, 2012 | 03:43 PM
FastGhost's Avatar
FastGhost
I turned TC off, 28psi in tires. Tried from idle, then slightly higher rpm(best short time), then started brining it up against the convertor later. My best was early runs.
I'm surprised you have that much tire pressure in street tires...I was thinking like 18 psi..so Invos aren't that bad. After a couple of near crashes with the TC off I'm skished about going WOT on a launch..warmmed the tires are better control...I may have to get a line lock for burn outs.
Old Sep 18, 2012 | 09:21 PM
ALVETTE00's Avatar
ALVETTE00
MPH is def low for that rwhp, but what was the DA at the track the time you ran?
