heading to the track tonight
) and as long that hard hittin' big stall can still hook in cold weather (MIR's legendary track prep should help there) then you have a VERY good shot at getting into the 10.2s.
Dare I say it, on a 1.35 sixty foot no less?
I like the way you think Marc!
Justin, I have been scratching my head for mph since I put the h/c in this thing. I did seem to pick up 1 mph with the ported intake though!
It seems like the stick cars are easily picking up 29-30 mph between the splits.. I routinely pick up 22-24
My compression should be up to ~10.85 when I do the head swap from about 10.6 now by running the .040 gasket instead of the .051(or .053,I can't remember what stock is)
i didnt know for sure if the plate was different then the nozzle, so its the same that's pretty good with a progressive system how was traction and finish line rpm
Joe you need to go for a ride in my car and it might surprise you that the trans doesn't feel as slippery as an old hot rod of days past.
anyone coming to indy in Oct for the lsx event?
The top's not slowing you down, notice Justasheet is a convertible too and traps exact same as me. Remember I also had my car up to 185 a few times on the mile run, my top didn't slow me down, I ran up to 6800 in 5th no problem.
It's the converter, if you lock it you'll go faster. You should call Jeremy Preston and ask him. He's the man on these things.
this still doesnt explain why I ran 121.56mph as a BEST speed with the same heads and cam with a STOCK converter. This car does not want to mph!!
Justasheet, what does your car mph locked vs unlocked? with same tune?
maybe you have one hanging up, are you leting off before the finish line, have you ran it at another track, maybe the mph timer is off, your 1/8 times are fine, and the top is slowing you down some and the converter, maybe your tune
I'm knocking on the door on the 52 pill...fuel system should go in next week after I sort out this clutch issue..
