2005 c6 transmission issues
Old Sep 19, 2012 | 10:36 PM
Fastcorvetteguy's Avatar
Fastcorvetteguy
Navigator
Default 2005 c6 transmission issues
I have a 2005 Chevy corvette, it's giving a component slippage code. Took it to my local dealership and they diagnosed it to torque converter or valve body. Paid them to install a new tranny. Same problem still same code. They don't have a clue about what's going on. They think it may have a rear end gear any answers? I think it may have been programmed wrong is this possible if the torque converter settings were changed?
Old Sep 19, 2012 | 11:55 PM
C6CorvetteZ51's Avatar
C6CorvetteZ51
So after this fix that didnt fix your problem, did you still pay full price? I had wiring and voltage problems recently. It ended up being a $300 fix at a local auto shop. The stealership wanted $8000 to rewire my whole car. They never bothered diagnosing the real problem. Replacing everything till the problem fixes itself is their only experience.
I dont know about your current problem. I would get some of your money back assuming that work fixed nothing. And find a quailty auto shop that has an idea what its doing. Dealership service should only be used under warranty in my experience. I have had what feels like every problem with my 05 and i havnt heard of this error code.
Old Sep 20, 2012 | 03:49 AM
cdkcorvette7's Avatar
cdkcorvette7
I would recommend you find a different mechanic if all your dealership is going to do is throw parts at it until the problem resolves itself. That'll get really expensive really fast (especially replacing major drivetrain components). If the problem was diagnosed as being related to the torque converter why did you replace your transmission and not just the converter?
Also, what mods do you have and what do you think was programmed wrong? Is all of this being done as a result of a DTC or are you experiencing actual symptoms; if so what are they?
Old Sep 20, 2012 | 08:25 AM
Fastcorvetteguy
Navigator
Thanks for the help..
Old Sep 20, 2012 | 12:15 PM
SpinMonster's Avatar
SpinMonster
At a minimum get the transmission back so you can sell it for 1500 since there isnt anything wrong with it.
Old Sep 21, 2012 | 03:21 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
Has your concern been resolved? Please contact me or Evan privately if you need additional assistance. Thank you.
Tricia, Chevrolet Customer Service (Assisting Evan).
Old Sep 26, 2012 | 08:37 PM
Fastcorvetteguy
Navigator
Default What up Forum 2005 corvette fixed
[QUOTE=Fastcorvetteguy;1581873392]I have a 2005 Chevy corvette, it's giving a component slippage code. Took it to my local dealership and they diagnosed it to torque converter or valve body. Paid them to install a new tranny. Same problem still same code. They don't have a clue about what's going on. They think it may have a rear end gear any answers? I think it may have been programmed wrong is this possible if the torque converter settings were changed.
Problem was resolved by programmer entering setup for a 3:08 gear. Instead of 2:73. Previous owner upgraded without programming. Thanks for all the help.
To 2005 c6 transmission issues
