I received LS7 Manifolds/cats/h-pipe from another forum member. There are a total of 5 studs missing from the manifolds, and 2 from where the cats connect to the h-pipe. Can the LS3 studs be used in replacement or will I need to get new parts at the dealer?
thank you, are the bolts that connect the cat to xpipe on the LS3 good enough to connect the cats to the hpipe on the LS7? My main concern is trying to find the part number for the studs that go into the LS7 header, and the ones on the end of the cats that connect to the H pipe
I bought all new studs, bolts, nuts and gaskets when I installed my LS7/9 manifolds and cats last year. It was quite a chore to track down those part numbers. I ordered everything from PartsTaxi.
The manifolds have 4 studs per side (8 total):
item 24 - part# 11518424
The cat to h/x pipe requires 1 stud and 1 bolt per side:
Studs (2 total) - item 19 and 27 - part# 11588356
Bolts (2 total) - item 13 - part# 11515768
The nuts for the studs (10 total):
item 12 and 20 - part# 11517996
Thank you very much, the exact info I needed. Is there a gasket that goes between the cat/h-pipe connection?
yes a circular exhaust ring...............should be with the cat pipe..#17 in illustration above...fits like a ring on the end where it mates to the midpipe..
i used all used bolts and nuts, but all new gaskets except the exhaust rings,they were also used..good luck
