Strange Problem...need help
Old Sep 22, 2012 | 08:28 PM
bubblehead1965's Avatar
bubblehead1965
Default Strange Problem...need help
I have a 2006 Z and today the passenger side speakers, window, door, door locks, and head light is very weak...just stopped working. Where would be a good starting point to figure this one out....would it be a fuse? Loose wire?.....what does all of these thngs have in common?
Thanks in advance
Old Sep 22, 2012 | 08:52 PM
RicK T's Avatar
RicK T
Might want to ask in the Z06 Forum.
Edit: Just went over there and you did ask already.
Old Sep 23, 2012 | 01:33 AM
JCtx's Avatar
JCtx
You didn't mention if you just bought the car or not. If bought used, you need to check for all possible modifications messing with the electrical system. You can start with the fuse box in front of the passenger's kick area, checking for codes with a scanner, and service history (if possible). More often than not is a bad installation. Or also a bad repair. Check under the seats as well, and push every connector you come across, in case they're loose. Your last resort is a dealer or reputable shop. Good luck.
To Strange Problem...need help
