SHarkbar harness bar install help
The hardware that was sent with the Sharkbar had 2 thick washers. The online instructions do not specify where these go.
Also there is a bit of gap between the bar and one of the mounts if I snug the bar down to one side.Should I just torque all the bar bolts evenly and draw the supports to the bar?
Any insight would be helpful.
Here are the instruction. http://vetteworksonline.net/acrobat/...orvette-r2.pdf
Here is the gap
And here's the spacers/washers
Gap is a bit more than the .20 thickness of the spacers
Still looking for the template
