Fuel Pump removal and replacement
Old Oct 8, 2012 | 10:33 PM
ClaudeB's Avatar
ClaudeB
5th Gear
Default Fuel Pump removal and replacement
What is the easiest way to remove the fuel pump in a 2007 Corvette and to replace the fuel pump?
Old Oct 8, 2012 | 11:45 PM
Perhaps this would be better in the C6 General or Tech section - you've placed this in the C5 General section of the forum.
Old Oct 8, 2012 | 11:54 PM
8VETTE7's Avatar
8VETTE7
Try C6 tech section.
Old Oct 9, 2012 | 10:39 AM
haljensen's Avatar
haljensen
There is no "easy way". The fuel pumps are in the gas tanks behind the seats under the rear tub.
Old Oct 9, 2012 | 10:50 AM
DaytonaFIC6's Avatar
DaytonaFIC6
It's really not all that bad. There is a write up somewhere on how to do it without dropping the rear end and transmission.
Old Oct 9, 2012 | 11:55 AM
taken19's Avatar
taken19
Track Junky
Find a post in the DIY sticky, post #5. It explains it all. Not too bad with the drivetrain out of the car, a pain if not removed.
http://forums.corvetteforum.com/c6-t...fuel-pump.html
To Fuel Pump removal and replacement
