Coolant Change
Old Oct 11, 2012 | 10:06 PM
Mike Green9's Avatar
Mike Green9
Default Coolant Change
Hi.
I have 20,000 miles on my 2008 C6.
For maintenance reasons, I will be changing the Dexcool this fall.
The plan is to drain the rad and remove the thermostat, to get as much Dexcool out of the engine/rad without actually flushing the system. If the fluid comes out clean, then I will just add a 50/50 mix of distilled water and AC Delco Dexcool.
Questions:
1. Do I have to add any sealant/lube on the thermostat "O" ring and flange?
2. Is any sealer/lube required on the thermostat bolts?
3. Is there a safe way of getting any air locks out of the engine? I noticed there is a bleeder hose of sorts coming out of the filler reservoir. Should I try blowing into this hose to help burp the system?
Thanks,
M...
Old Oct 11, 2012 | 11:39 PM
LS WON's Avatar
LS WON
Originally Posted by Mike Green9
Hi.
Questions:
Thanks,
M...
From what I have read there is no need to remove thermostat. Simply just open the draincock on passenger side on bottom of radiator and replace with same. You won't get all the old stuff out but that's the way the cooling system is unlike other cars that have a radiator cap on top of radiator to do a superflush until you get clear running water with no anti-freeze in it.
Old Oct 12, 2012 | 08:35 AM
davekp78's Avatar
davekp78
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Just draining the radiator by opening the draincock will leave a lot of coolant in the block. Loosening the thermostat housing will allow much of the coolant in the block to drain.
Old Oct 12, 2012 | 09:19 AM
Mike Green9
Thanks for the replies.
I plan on putting in a 180 stat (Lingenfelter)- so I have to remove the old one anyways.
Do I run the "O" seal and bolt threads dry?
Thanks,
M....
Old Oct 12, 2012 | 09:54 AM
LEAVINU's Avatar
LEAVINU
Nothinig needed on the bolts but I personally like the added confidence of a little liquid gasket around the housing. I've reused the thermo o-ring numerous times without issue but always spread a thin film on the housing just in case.
Old Oct 12, 2012 | 10:56 AM
LS WON's Avatar
LS WON
This is exactly what the dealership does.
Old Oct 12, 2012 | 10:58 AM
LS WON's Avatar
LS WON
Locktite
Old Oct 12, 2012 | 11:25 AM
LEAVINU's Avatar
LEAVINU
Originally Posted by ram air
Locktite
Not saying you dont have to but I've never used it on mine and mine has been off close to 8x atleast.
Old Oct 15, 2012 | 07:28 AM
GOLD72's Avatar
GOLD72
I just did my 07 LS2 vert over the weekend. I carefully measured the drainable coolant just for future reference. I turkey bastered the surge tank first. It is real close to 36 oz total capacity. Next I drained the radiator and whatever else came out with it. That was another 6 qts. That left about 5-1/2 qts in the block by my estimation with a 12.5 qt system. I did a drain and refill twice to get as much out as possible. My coolant still looked great at 21k+ miles so I felt the 2x change was good enough. BTW - the surge tank will drain thru the radiator drain so the turkey baster is unnecessary other then to measure the surge tank capacity separately.
To Coolant Change
