DRM Bilstein shock install
Old Oct 19, 2012 | 08:55 PM
chaver450's Avatar
chaver450
Default DRM Bilstein shock install
Just finished installing my front shocks. They are slightly shorter than stock but the positioning of the collar makes them even shorter when installed. I had to jack up the A arm to bolt in the top of the shock. It seems like that would limit my travel. Anybody install these lately and is this normal?
Old Oct 20, 2012 | 02:40 PM
chaver450's Avatar
chaver450
No one?
Old Oct 20, 2012 | 02:49 PM
C6LS3's Avatar
C6LS3
Originally Posted by chaver450
No one?
i recently installed mine about 3 weeks ago. i experienced the same but didn't think much about it till you reminded me. i also had to jack the A arm a little to get the rear shocks installed. fronts were just fine if i remember correctly. car feels great compared to stock. c6-base suspension. i would like to know what others think about your inquiry.
Last edited by C6LS3; Oct 20, 2012 at 02:52 PM. Reason: spelling/additional comment
Old Oct 20, 2012 | 03:59 PM
chaver450's Avatar
chaver450
Thanks for the info. I'm looking forward to others' experience as well. I'm doing the rears today. Wish me luck.
Old Oct 20, 2012 | 04:09 PM
LFZ's Avatar
LFZ
The total length of the drm shock is about 1-1.5" shorter than stock. Nothing wrong with the way you are installing them.
Old Oct 20, 2012 | 05:32 PM
Thunder8's Avatar
Thunder8
I installed mine about 6 months ago on a C6 coupe and it was like night and day from the stockers. Back to your question, that's normal. My understanding was that this shock was also designed for vehicles where the suspension may be dropped/lowered slightly and are the best shocks if that was your plan, if not, they're fine anyway.
Old Oct 20, 2012 | 09:22 PM
SLAZ06's Avatar
SLAZ06
Just installed 4 Bilsteins and as you found they are slightly shorter. I have not noticed an y issues other than an improved ride and handling.
Old Oct 20, 2012 | 10:03 PM
newvetteguy9's Avatar
newvetteguy9
Where are you guys getting yours and how much?
Old Oct 20, 2012 | 10:19 PM
Thunder8's Avatar
Thunder8
http://www.shockwarehouse.com/index....cted_year=2008
I think I got mine here, happy with the service. Wow, seems like they've gone up since last year, oh well. I think they're one of the best that can be had, besides a good set of coil-overs, but then we're really not comparing apples to apples.
Old Oct 20, 2012 | 11:35 PM
LFZ's Avatar
LFZ
Just FYI (as mentioned by the OP) Those linked above are the not DRM Bilstein shocks specifically valved for the C6 Z06. Those are heavy duty regular Bilsteins which are completely different.
The only place to purchase DRM Bilsteins is from Randy at Doug Rippie Motorsports.
Old Oct 21, 2012 | 04:01 PM
PCMusicGuy's Avatar
PCMusicGuy
Totally normal. I've been running them on my 07 Z51 for the last couple thousand miles and they have been great.
Old Oct 21, 2012 | 07:29 PM
Olddudesrule's Avatar
Olddudesrule
As said, normal. Did all four four months ago, and love it. Didn't affect ride height much if any. Measured was less than 1/4-1/2" on any corner.
Old Oct 21, 2012 | 08:07 PM
Thunder8's Avatar
Thunder8
Yes, I forgot to point that out, I'm sorry, didn't mean to confuse it. I'm not sure of the valving differenes exactly, but other than that, which can make a big difference, the shocks are the same. I would say this though, that unless you have a Z06 or have the Z06 leafs and other suspension components, they may be a bit much. I'm sorry, I wasn't clear if these were going on a Z or not.
I can say that with my z51 suspension, that the "heavy duty" Bilstein's I have seemed to be matched perfectly. I would recommend the Bilstein's, either shock, over just about any other on the market, unless you go with some good coil-overs. The Bilstein's are stiff, but not overly so and their ability to recover and rebound is unmatched! Best shock you can buy for the money, by far!
Old Oct 22, 2012 | 12:08 PM
JerriVette's Avatar
JerriVette
All this talk of new shocks has me wondering at what mileage you guys decided to change out your shocks...?
I have 55k miles on my 08 C6 Z51 and didn't notice any issues...but as many of you are aware sometimes things like shocks can over time degrade without the owner realizing it..
How did you guys make the determination you needed new shocks...?
mileage or cause? Thanks in advance..(street only)
Also how did you determine you wanted DRM bilstein shocks versus traditional Bilstein sport shocks?
Did you buy the extra cost bushing from DRM instead of the bilstein bushing and if so why?
What made the DRM a better choice for a Z51 coupe vs DRM shocks for a Z06? Thanks.
Old Oct 22, 2012 | 12:28 PM
LFZ's Avatar
LFZ
I have had some good experiences in the past when I ran DRM Bilsteins on my C6 Z06, so I answered your questions below in red. Hope this helps.
mileage or cause? Thanks in advance..(street only) I wanted new shocks because the factory shocks are just lackluster in regards to performance and ride.
Also how did you determine you wanted DRM bilstein shocks versus traditional Bilstein sport shocks? I chose DRM because of all the "real life" positive reviews it was receiving on the Z06 forum from track to street use.
Did you buy the extra cost bushing from DRM instead of the bilstein bushing and if so why? If you track, I'd recommend the poly bushings, but I went with the rubber bushings Bilstein provided. I have no other poly bushings on the car and did not want to roughen the ride even more. The poly bushings do make the shock work harder which is a good thing on the track IMO.
What made the DRM a better choice for a Z51 coupe vs DRM shocks for a Z06? Thanks. DRM Bilstein shocks are specifically designed for the C6 Z06 ONLY. Although, they can be used on base C6s with no negative side effects.
The stock Z06 with its factory shocks suffered some stability issues such as "twitchiness" as well as a floaty feeling at the rear end. The DRM shocks cured this unwanted feeling, by giving you a more planted and absorbant ride do to its specific valving. The main thing I liked about the DRMs was that they were not as bumpy across mediocore roads and the planted feeling inspired confidence when entering and exiting a curve. I also noticed my tendency to wheel hop the car decreased tremendously. In fact, I never wheel hopped with the DRMs unlike the stock setup.
Old Oct 22, 2012 | 12:40 PM
JerriVette's Avatar
JerriVette
thank you for your insight!
Old Oct 22, 2012 | 01:40 PM
C6LS3's Avatar
C6LS3
I did it for almost the same reason as LFZ at 14,500 miles on my base 2011 coupe. After installing the DRM Bilstein shocks it removed the rear end "twitchy-ness" and smoothed out the bumps on the road. The "jarring" bumps feel like butter after the install.
To DRM Bilstein shock install
Old Oct 22, 2012 | 01:59 PM
newvetteguy9
So are you guys using the actual drm or just the hd ones?
Old Oct 22, 2012 | 02:09 PM
C6LS3's Avatar
C6LS3
I'm using DRM Bilsteins.
Old Oct 22, 2012 | 02:10 PM
boraxman's Avatar
boraxman
I picked up a new set of DRM's w/ poly bushings a couple months ago and changed out my stock z51 shocks at 8000miles, the DRM's are way better but you do feel the road more.
