Catch can question
Old Oct 20, 2012 | 07:07 PM
trojan67's Avatar
trojan67
Default Catch can question
Just installed a catch can I got from Cajun. He took great care of me on the sale. Can anyone tell me how often I should expect to empty it? I don't race or drive really hard, not sure if that matters. Thanks for the info.
Old Oct 20, 2012 | 07:28 PM
RicK T's Avatar
RicK T
No personal experience but here's a discussion to get you started.
http://forums.corvetteforum.com/c6-t...neth-over.html
Old Oct 20, 2012 | 07:32 PM
YELW 06 Z51's Avatar
YELW 06 Z51
I had mine on for close to 2k and its about 2 inches full, so not that often. The car has seen high rpms pretty much every time I go out but not anything continuous like at a track.
Hope this helps
Old Oct 20, 2012 | 07:49 PM
trojan67's Avatar
trojan67
thank you for the information. I think I will check it in a few thousand miles and then either increase or decrease the frequency accordingly.
Old Oct 20, 2012 | 09:10 PM
JCtx's Avatar
JCtx
What increases oil collection is high vacuum, not necessarily high rpm. Therefore if you do a lot of coasting, it's going to collect more than just high rpm. Bottom line is it's going to depend on your driving habits. I'd pretty much do what you said: check it at 1K rpm, and adjust your interval accordingly.
Old Oct 20, 2012 | 09:38 PM
VET4LES's Avatar
VET4LES
We hear different amounts of oil from different owners. Some find lot's oil in a short time and others like me see almost none. I will be removing mine in a few months for my smog test and will take a good look at it then. I will reinstall it after the test.
Old Oct 21, 2012 | 10:11 AM
RussM05's Avatar
RussM05
Why do you say that? My understanding is at high rpm there is more oil mist in the crank case thus more oil in the air going into the catch can.
I drain mine every oil change. I get about a shot glass of oil from just street driving cruising with a few WOT runs.
Old Oct 21, 2012 | 12:30 PM
Mike's LS3's Avatar
Mike's LS3
There is more oil vapor that gets pulled into the intake at high rpm on deceleration. Vacuum is at the highest on deceleration. At WOT vacuum is at 0. Therefore, oil vapor gets pulled into the intake on deceleration. You are correct at higher rpm more oil vapor is produced, but it needs to be pulled into the intake with vacuum.
Old Oct 21, 2012 | 01:36 PM
RussM05's Avatar
RussM05
Manifold vacuum at WOT is low but not zero. I scan my tune and the MAP at WOT ranges from 94kpa to 99 kpa with 100 kpa equal atmospheric pressure
Add to that the blow-by at high rpm WOT that pressurizes the crank case and pushes that oil mist out thru the PCV into the catch can.
You are correct that on deceleration vacuum is high and pulls air and oil mist into the catch can.
Old Oct 21, 2012 | 04:18 PM
Mike's LS3's Avatar
Mike's LS3
I have measured vacuum on my carburetor performance engines with 0 vacuum in inches of mercury (inHg) on a non computer car. I have not logged readings using kpa with the corvette. I am assuming that the readings will be between 97-100 kpa, if less, it may reflect a restriction in the TB or intake system. Now you got me curious.
To Catch can question
