Radiator shroud question
Old Oct 22, 2012 | 07:00 PM
schizcat's Avatar
schizcat
Default Radiator shroud question
Quick question for ya'll. Has anyone cut their radiator shroud for a non ram air CAI (K&N)? Looking at the design of it, the K&N looks like it would breath better if it got more direct air flow. Someone has to have done this before, wondering what the results were.
Old Oct 22, 2012 | 08:29 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Absolutely. For a clean look check out the vette-air, but there is also this option http://forums.corvetteforum.com/c6-t...gle-bolts.html.
Old Oct 23, 2012 | 06:57 PM
haljensen's Avatar
haljensen
The K&N is not a CAI.
If you cut the shroud then any filter/filter box becomes a CAI.
Old Oct 23, 2012 | 09:15 PM
Motorhead-47's Avatar
Motorhead-47
Yep....a sharp box knife is all it takes...
Old Oct 24, 2012 | 02:14 AM
Mike's LS3's Avatar
Mike's LS3
It is not recommended to cut area #3, surging may occur at cruise speeds due to turbulent air flow into the MAF sensor. This applies to the LS3/7. I have areas #1 and #2 cut out which supplies plenty of cold air. Recently, the center retainers in #3 area started pulling away opening up a gap in the middle, this gap started to create a slight surge at cruise speeds. I closed the middle gap up and the surge stopped. Just passing along what I experienced.
Old Oct 26, 2012 | 07:58 PM
schizcat's Avatar
schizcat
Thanks for the pics and the info gents. Yeah, I would also think that area #3 would keep it "sealed" to the body. What is your recommendation on cutting the indented area in the center open? I guess what you would do with a Varoom. I would almost think that you may bring in hotter air because of the radiator. Thoughts?
Old Oct 26, 2012 | 08:18 PM
Motorhead-47
I don't cut Area #3 on LS3 cars..more sensitive to disturbed airflow. These cuts are forward of the radiator.
Old Oct 26, 2012 | 08:22 PM
schizcat's Avatar
schizcat
What about LS2?
To Radiator shroud question
