T.p.m.s. Codes malfunctioning
Old Oct 25, 2012 | 09:10 AM
jack5hd's Avatar
jack5hd
Default T.p.m.s. Codes malfunctioning
Hi, i have 2011 g.s. With 28thousand miles.yesterday the tire warning light came on .checked the air pressure on the dic display and it showed xx for pressure on left rear tire,false reading then few miles later showed xx for both rear tires.kept driving and codes went away...we were on a 300 mile drive and this happened couple times more......last time showed left front tire at xx....any ideas?also my new passport 9500ix radar detector with live alert cord couldn't lock on to the g.p.s. ...coincidence?thanks.j.k.
Old Oct 25, 2012 | 01:04 PM
BEZ06's Avatar
BEZ06
Sounds to me like your tire pressure sensors are not programmed into the TPMS computer memory in the car. The batteries in the sensors are designed to last about 10 years, so it's very unlikely that all 4 sensor batteries are dying in sensors on a 2011.
I looked in your profile to get some info about your car, but there's nothing in your profile.
Do you have your original wheels on the car?
I'm assuming you've had a new set of tires installed if you've got 28,000 miles on it - did they use the original sensors in the new tires?
Do you have your OE wheels, or has a different set been installed that might have a different set of sensors?
The memory of the TPMS computer in the car can only hold 4 sensor ID#'s, so if you've changed to a different set of wheels or otherwise had different sensors installed, it sounds like the sensors aren't properly programmed into the TPMS.
The lack of GPS reception by your 9500ix is a coincidence. I have a 9500ix as well and have never had any GPS problems. Where do you have it mounted? You do need to have it forward enough so it's out from under any metal like the windshield frame or the rearview mirror that might restrict the signals being picked up by the antenna. I have mine on a Great Lakes Trophy visor mount, and other forum members use the Blendmount unit to attach it under the rearview mirror. You shouldn't have any problem receiving GPS signals with either of those mounting solutions.
The greatest features of the 9500ix require GPS position info (red light cameras, speed cameras, known speed traps, etc.), with one of the best features being how it locks out known false alerts from door openers, etc. So, you definitely want to get the GPS working!!!
Also, make sure you update it regularly - the Escort database is updated weekly (new one comes out every Monday), and here in Florida there are numerous new redlight camera locations almost every week!!
Bob
Old Oct 26, 2012 | 08:41 AM
jack5hd's Avatar
jack5hd
thanks bob..............had new tires put on 12 thousand miles ago on original wheels.also radar detector has been in same spot for over a month.it is working now.............i'll see what happens....
To T.p.m.s. Codes malfunctioning
