what is the highest compression with pump gas
Old Oct 27, 2012 | 01:45 PM
2fastfu's Avatar
2fastfu
Default what is the highest compression with pump gas
How high of compression can I go with 91 octane (only 91 available in AZ)? Car is a 402ci with trick flow 225's, stock size MLS gasket,not milled just shaved to removing any imperfections. It should be at the 10:8 or 9 still right? I heard you can run as high as a 12:1 or 11:5 to be safe. The shop that built my motor said they would never go over 11:1 on any pump gas motor. What are gains can be had with 11:1,11:5, or 12:1?
can someone tell me what compression I am at now? 0.50 Gaskets, TF 65cc combust chambers, and heads and block were decked. Or is it not that simple?
Old Oct 27, 2012 | 04:52 PM
John Harry's Avatar
John Harry
St. Jude Donor '10-'11-'12-'13-'14
Depends to some extent on the dynamic compression ratio, which is related to the particular cam you are running.
