Drivers air bag connection
Old Oct 28, 2012 | 12:43 PM
socalenergyman's Avatar
socalenergyman
Default Drivers air bag connection
When I removed the drivers seat I failed to disconnect the airbag connector. When I lifted the seat, the wires pulled out of the connector. All the wires look good without any insulation damage and the crimps all look fine. Problem is I don't which wire goes in which hole in the connector. I pulled the passenger seat and the color codes are different.
Does anyone have a pic or know the pinouts for the drivers seat airbag connector?
Old Oct 28, 2012 | 03:40 PM
marc8090's Avatar
marc8090
Can you match up the wire colors to the other half of the connector which the wires did not pull out from?
Old Oct 28, 2012 | 05:04 PM
BEZ06's Avatar
BEZ06
Scroll way down to the bottom of this site and you'll see pics of the info from the Service Manual with wire colors:
http://www.kawal.net/power%20seats.htm
Bob
Old Oct 29, 2012 | 01:23 PM
socalenergyman
Thanks but that shows for a zo6 I need for a c 6 and not all the colors of wire are shown---I need a pic of the yellow connector that goes from the car to the seat drivers seat
Old Oct 30, 2012 | 01:34 PM
Flame Red's Avatar
Flame Red
Search is your friend
Old Sep 4, 2020 | 03:25 PM
brinkmanms's Avatar
brinkmanms
3rd Gear
Default For the record
Did the same thing today...pulled driver's side seat out of my 2009 C6 and in so doing, pulled all 4 pins out of the vehicle side of the airbag connector. Paniced like crazy, as I had no reference as to where they originally were. Found this thread, and the link with the callouts toward the end is perfectly on point.
Old Jul 15, 2025 | 09:28 AM
J.sandberg's Avatar
J.sandberg
5th Gear
Default Air bag connection driver side c6 2006 mod
Hi, did you get the wiring tiagram air bag driver side seat? Were can i find it? Or picture of the 4 wires?
thank you
To Drivers air bag connection
