Anyone chipped an LS3
Old Oct 30, 2012 | 03:30 PM
Barryga's Avatar
Barryga
Default Anyone chipped an LS3
Does anyone have any experience chipping a LS3, I was looking at the Gforce and they claim my 436 hp will go to almost 500?
Price is right and if this is the case, then maybe the 2011 will keep up with the 74, Pro's/Cons????? the 11 has 3000 miles on it if that matters.
http://www.gfchips.com/chevroletcorvette.aspx
Is this a scam?
Barry
Old Oct 30, 2012 | 04:15 PM
RainMan12's Avatar
RainMan12
Don't waste your money. All it does is alter the intake air flow sensor temperature reading to the ECM to try to trick the car in changing the fueling. It's a completely wrong way to go about trying to tune a car.
Old Oct 30, 2012 | 04:41 PM
Zoxxo's Avatar
Zoxxo
Originally Posted by Barryga
Is this a scam?
Pretty much. You can look at this in one of two ways - either the company knows that it's a lie (see above post) but still sells it anyway which makes it a scam. OR, they don't know that it doesn't work on Corvettes in which case why would I want to install something on my motor from a company that doesn't know what they're doing? Take your pick.
Z//
Old Oct 30, 2012 | 04:44 PM
Gabbiani's Avatar
Gabbiani
Pretty much anyone that refers to it as chipping on the newer vehicles don't know what they are doing or trying to scam you.
The stock ls3 tune has plenty of timing and is maybe a little rich at wide open throttle. A few horses can be found.
Old Oct 30, 2012 | 05:05 PM
FloydSummerOf68's Avatar
FloydSummerOf68
A full tune will pick up 10-12ish horsepower
Old Oct 30, 2012 | 06:52 PM
EuroRod's Avatar
EuroRod
It also changes the ratio between the throttle pedal position and the throttle, so the engine sees more throttle with less pedal.
scam.
Old Oct 30, 2012 | 09:02 PM
Streetk14's Avatar
Streetk14
DO NOT BUY THAT G-FORCE GARBAGE! It is literally a module or "chip" that splices into the IAT sensor wiring. It is NOT a new ECM calibration or "tune".
If you want a little more power, get a good dyno tune or mail order tune from a reputable shop. On a stock LS3, I don't think you'll get much more than ~15 rwhp, but I could be wrong on that.
Old Oct 30, 2012 | 09:04 PM
1BADLS3's Avatar
1BADLS3
Snake Oil
Old Oct 30, 2012 | 09:16 PM
Barryga's Avatar
Barryga
Thanks guys, that is why I asked, as I knew you guys would know!
When is a $1.00 per 1 horse power of gain, not a deal! LOL
Barry
Old Oct 30, 2012 | 09:25 PM
bosco 08's Avatar
bosco 08
If that thing really worked and gave the gains as stated you would think the factory would be jumping all over that for only $89.
Old Oct 30, 2012 | 09:37 PM
ShaneFap's Avatar
ShaneFap
I prefer dorito chips.
Old Oct 31, 2012 | 10:18 AM
Streetk14's Avatar
Streetk14
The Cool Ranch ones are pretty damn good
To Anyone chipped an LS3
