Harmonic Damper replacement
Old Oct 31, 2012 | 07:20 AM
Ryan07's Avatar
Ryan07
Default Harmonic Damper replacement
Hello all,
I'm getting ready to swap out the dancing pulley on my car and thought I had read somewhere on here that you can push the motor up a bit with a jack and the crank bolt and pulley without removing the power steering rack. Is it possible? I did a search and all I've been able to find was the cost when people took theirs to the dealer and the procedures in the TSB for the loose bolt.
Thanks,
Ryan
Old Oct 31, 2012 | 09:10 AM
EVRose's Avatar
EVRose
I've read just about every thread there is on the subject and I've never heard of it done that way. Usually its done at the dealer and they always move the steering rack.
Old Oct 31, 2012 | 09:36 AM
C6RaceCar's Avatar
C6RaceCar
Originally Posted by Ryan07
Hello all,
Thanks,
Ryan
I highly doubt that. I wouldnt risk the firewall for that.
Old Oct 31, 2012 | 10:40 AM
Redrocket1045's Avatar
Redrocket1045
Hello all,
Thanks,
Ryan
You either lower the engine with cradle assy or remove the p/s rack. Those are the only 2 methods I know of.
Old Oct 31, 2012 | 07:34 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Old Nov 1, 2012 | 01:15 AM
Blk 08 C6's Avatar
Blk 08 C6
Hello all,
Thanks,
Ryan
what pulley damper are you swapping in there?
Old Nov 1, 2012 | 01:54 AM
JCtx's Avatar
JCtx
Hey, you can always try. If you succeed, you'd be the hero of the forum .
Old Nov 1, 2012 | 01:40 PM
Ryan07's Avatar
Ryan07
Well. I guess I will see how much room there is or isn't when I do mine.
Thanks guys.
Old Nov 3, 2012 | 02:21 AM
Ryan07's Avatar
Ryan07
Powerbond. Doing it tomorrow if you want in on the fun. Removal an install tool showed up yesterday from SPX.
Old Nov 3, 2012 | 03:42 AM
torquetube's Avatar
torquetube
Hello all,
Thanks,
Ryan
Yes. What you're actually doing is leaving the engine where it is and slightly dropping the subframe (with rack attached). This will require an extra jack and additional jack stands, but will provide better access to the bolt.
Old Nov 3, 2012 | 03:03 PM
Blk 08 C6's Avatar
Blk 08 C6
cool.did you get one for Eric think he needs to replace his.waiting on my Innovatorswest Inc. 10% overdrive 8rib setup.
Old Nov 3, 2012 | 07:25 PM
BoosterClub's Avatar
BoosterClub
IDK how you get the pulley off that way, no room for a puller. Don't forget to index the pulley to the crank and weight the new pulley the same way as the old. The rotating assembly is not balanced all that great during assembly and they use the pulley and flywheel to get it into spec.
Old Nov 11, 2012 | 01:27 PM
Ryan07's Avatar
Ryan07
Got it done. Rack came out to do it. No weights to transfer from the old one.
No more chirping or smell of burning rubber from the engine any more.
Rex, I haven't ordered a pulley for anyone. I'll see how this one holds up. Don't need the 8 rib at this point and won't need it until the car is paid off.
Old Nov 11, 2012 | 11:24 PM
Blk 08 C6's Avatar
Blk 08 C6
cool.goin that route.sliding the rack out of the way.glad I have a 2 post lift.
Old Nov 12, 2012 | 03:51 AM
Ryan07's Avatar
Ryan07
A lift certainly isn't necessary, but it made some things easier on the back.
Old Nov 12, 2012 | 12:37 PM
One Kick's Avatar
One Kick
Is there a link on changing out the damper, it is on my winter list and any way I can make it easier would be great. Thanks
Old Nov 12, 2012 | 04:16 PM
Ryan07's Avatar
Ryan07
There was an article that shows some pictures of the process.
http://www.gmhightechperformance.com...s/viewall.html
The guys at A&A have alson done a great job at writing the steps for removing the power steering rack. You can find it in the install instructions on their website.
Good luck. It's a fun job.
To Harmonic Damper replacement
Old Nov 13, 2012 | 03:29 AM
hefti2's Avatar
hefti2
I also did it the way of droping the front cradle a couple inches instead of pulling the steering rack.
Steering rack WOULD be simple IF the P/S lines wouldn´t run around the brake lines which is really soo stupid! Barely accessible and a major PITA.
Also a big b*tch was
1. to remove the center screw. I had one sat in the car, pushing the brake, tranny in 6th and a looong breaker bar to crack it open
2.to pull the pulley off the CS. It was stuck big time.. My puller almost gave in to it.
Also I still don´t understand how I should orientate the new damper on the crank regarding balancing. The old one was separated already and there are no weights, just holes in the outer ring.
Besides: How would I balance it with an e.g. Fluidampr? Not at all, right?
Old Nov 13, 2012 | 10:18 AM
BoosterClub
You would have had to mark the old pulleys orientation and line the new one up.
Old Nov 13, 2012 | 11:54 AM
hefti2's Avatar
hefti2
Ok, maybe I am just a little retarded here but I still don´t get it right:
The old balancer was apart already, meaning the outer ring with all the balancing holes was freely rotating resp. separated from the inner ring.
So marking the old pulley (inner ring) is meaningless or am I wrong?!
And the new pulley had AFAIR no marking which could have been used as an orientation compared to the old pulley..
And still: How is it when installing an aftermarket pulley? I guess they are balanced to zero by themselves so can´t do anything to "fine-balance" the crank assembly. Or am I wrong again?
Thanks for helping me out here...
