Stainless master cylinder line?
Old Nov 1, 2012 | 10:20 PM
BoosterClub's Avatar
BoosterClub
Default Stainless master cylinder line?
I thought a few companies sold a stainless line to replace the rubber one near the heat of the headers, but searching now I can't find one?
Old Nov 2, 2012 | 10:24 AM
BEZ06's Avatar
BEZ06
Are you talking about the clutch???
If you're talking about the line from the clutch reservoir down to the clutch master cylinder, I'm not aware of any SS line available, and I don't know why you'd need one.
Bob
Old Nov 2, 2012 | 07:58 PM
BoosterClub
Bob
No, down to the torque tube, the one that passes by the headers, don't want it exploding on me from heat and want to change it while I have it apart.
Old Nov 3, 2012 | 05:08 AM
Legal Alien's Avatar
Legal Alien
I think you are talking about the line from the clutch master to the clutch slave which is down in the torque tube?
When I fitted my tick adjustable master they offered the option of a one piece stainless line but this would have entailed taking the drive train out to fit. Not worth it just for the line but as you say, whilst you've got it apart it's prob a great idea.
Don't know whether the tick line would work with the standard master though?
Old Nov 3, 2012 | 11:10 AM
BoosterClub
Yea I imagine it wouldn't be compatible, but I'll ask them.
Old Nov 3, 2012 | 05:13 PM
JCtx's Avatar
JCtx
Plastic high-pressure brake line? It'd crack with the pressure. They have to be metal man. But they do have a sleeve (probably silicon, to withstand the heat). The actual M/C is plastic, but the lines should be metal. Curious for somebody to confirm or deny this.
Old Nov 3, 2012 | 06:44 PM
BoosterClub
Who said anything about plastic? There's a rubber section, like OEM caliper to hardline hoses.
Old Nov 3, 2012 | 07:29 PM
JCtx's Avatar
JCtx
Sorry man. Need something flexible there if you don't want trouble. It's too short to make any difference IMO, but you could replace it with a braided S/S flexible line, if you want. Good luck.
Old Nov 3, 2012 | 09:27 PM
BoosterClub
Which is what the whole thread was about from the start...
Old Nov 4, 2012 | 04:46 PM
glenB's Avatar
glenB
St. Jude Donor '08-'09 & '12, '14
Look into Ram Clutches new hydralic throwout kit, either way, to replace the factory hose you will need to remove torgue tube.
You can also check with McLeod
http://www.mcleodracing.com/products...lt.asp?id=5206
Old Nov 4, 2012 | 06:37 PM
JCtx's Avatar
JCtx
You should improve your writing skills then .
Old Nov 4, 2012 | 09:55 PM
BoosterClub
Yea it's already out, which is why I want to replace it now.
Or maybe you need to work on your reading skills, everyone else understood.
To Stainless master cylinder line?
