Which extensions for ZO6 manifold install?
Old Nov 6, 2012 | 11:56 AM
nmarple254's Avatar
nmarple254
Default Which extensions for ZO6 manifold install?
Trying to find out which O2 extensions I need for my ls2 ZO6 exhaust install. Any help would be appreciated. I'm trying to get 12" ones but have only been able to find 24".
Old Nov 6, 2012 | 01:32 PM
HOXXOH's Avatar
HOXXOH
None are required. Simply unwrap the taped harness until you have the length needed, then retape the remainder. Since the O2 wiring will cross near the Z06 manifolds, be sure to tie it away from excess heat.
Old Nov 6, 2012 | 01:44 PM
nmarple254's Avatar
nmarple254
I have heard about that but also that if you jack it up that harness is a couple hundred bucks so I was sketcy on doing that.
Old Nov 7, 2012 | 01:57 AM
HOXXOH's Avatar
HOXXOH
If you have a fear of peeling back some electrical tape, pay someone else to do it.
Old Nov 7, 2012 | 07:16 AM
1fastbob's Avatar
1fastbob
To avoid hacking into the wiring harness use 12" extensions for the front sensors. I removed some tape on my 2006 Coupe and will replace it and order 12" extensions. I didn't like the routing I ended up with and it looks like crap. Note...front extensions are different than rears extensions (don't need any for the rear).
Old Nov 7, 2012 | 08:35 AM
MR_JLR's Avatar
MR_JLR
I got mine on ebay
just searched for you and seller joemama2 and another seller tpi_parts(who I got mine from) have the 12" extensions you need
Old Nov 7, 2012 | 09:15 AM
nmarple254's Avatar
nmarple254
Thanks for the help
To Which extensions for ZO6 manifold install?
