Tpms
Old Nov 6, 2012 | 06:13 PM
tusc6's Avatar
tusc6
Default Tpms
How accurate is tire pressure reported by the TPMS. My onstar report shows 3-4 psi lower than my pressure gauge. I use a quality, made in USA gauge.
Old Nov 6, 2012 | 06:23 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
My TPMS have been within 1 psi of my digital gauges, on those occasions when I've checked. But that doesn't mean they are all that good. Many people report they become less accurate at higher elevations, which might apply to you.
Old Nov 6, 2012 | 06:33 PM
BEZ06's Avatar
BEZ06
I looked in your profile to see where you live - but "Arizona" didn't nail it down very close!!
The sensors are very accurate, however the TPMS only reports to the nearest 1.0 psi, or at least that's all the closer the DIC is able to display.
I have a high end TPMS tool and it displays to the nearest 0.2 psi, and it gets the signal transmitted by the sensor to the TPMS, and is virtually identical to my accurate hand held pressure gauge:
HOWEVER.....I live at sea level!!!
The DIC display (and the pressure the TPMS sends to OnStar) will be approximately 1 psi less than your hand held gauge for every 1,000 feet of elevation above sea level.
I bet you live up in Prescott where the elevation is about like Denver - a little over 5,000 feet. That would easily account for 3 or 4 psi less on the DIC than your hand held gauge.
Even Tucson is about 2,600 feet and owners there should see about 2 psi less on the DIC than their hand held gauge.
Bob
Old Nov 6, 2012 | 07:21 PM
tusc6's Avatar
tusc6
Good info thanks. My house in Tucson is about 3000 ft elevation, so that would account for the difference.
To Tpms
