CAGS Skip Shift Eliminator
Old Nov 7, 2012 | 02:20 PM
Brudix's Avatar
Brudix
4th Gear
Default CAGS Skip Shift Eliminator
Before trading in my 2008 coupe, I removed the CAGS skip shift eliminator. I then installed it on my new 2013 ZR1. The check engine light came on. So, I took it back off. It worked great on the 2008. Does anyone have a soulution to this problem. I would really like to not have the computer controlling my shifting on my awesome ZR1.
Old Nov 7, 2012 | 03:30 PM
CWHPARTS's Avatar
CWHPARTS
Platinum Supporting Dealership
WE HAVE INSTALLED OUR CAGS SKIP SHIFT ON SEVERAL 2013'S NOW WITH NO PROBLEMS AT ALL. THE RESISTANCE IN OUR UNIT IS MATCHED PERFECTLY TO WHAT THE COMPUTER IS LOOKING FOR. WE BUILD OUR UNITS IN HOUSE. WHEN THE 2013 CAME OUT WE TESTED OUR UNIT TO MAKE SURE IT WORK OR IF WE HAD TO BUILD A NEW UNIT. OUR CAGS WORKS FROM 97 TO 2013 GARUNTEEDED.
http://corvettesofhouston.com/corvet...ft-bypass.html
__________________
YOUR CORVETTE SUPERSTORE SINCE 1988
CORVETTE WORLD HOUSTON
281-821-1222
http://corvetteworldhouston.com/
Old Nov 7, 2012 | 03:45 PM
Brudix's Avatar
Brudix
4th Gear
Have you tested it on a 2013 ZR1?
Old Nov 7, 2012 | 04:03 PM
CWHPARTS's Avatar
CWHPARTS
Originally Posted by brudix
have you tested it on a 2013 zr1?
base,gs and z06 no zr1 yet, but if you buy one and it dosnt work for any reason i will pay for return shipping and give you a full refund.
I know it will work as all the 2013 manual trans use the same skip shift solenoid.
Old Nov 25, 2012 | 06:44 PM
Brudix's Avatar
Brudix
4th Gear
Default Cags
Okay, I'll order one and give it a try. Thanks.
Old Nov 25, 2012 | 07:07 PM
Brudix's Avatar
Brudix
4th Gear
Your website accepts my city, but the state field doesn't seem to be working.
Old Nov 25, 2012 | 07:50 PM
timd38's Avatar
timd38
Sounds like a great vendor!
Old Nov 27, 2012 | 07:14 AM
GOLD72's Avatar
GOLD72
I bought a new CAGS Defeat resistor assembly from a forum vendor and installed it on my 2011 ZR1 with no problems.
Old Nov 19, 2014 | 04:49 PM
ClydeSeverson's Avatar
ClydeSeverson
1st Gear
Default Question on Cags
I have a 2005 and am about to install a bypass harness. Instructions are not very clear. First I want to verify that the harness is on the drivers side of the transmission? and is there more than one harness? Any other things I need to be aware of?
Old Nov 21, 2014 | 12:18 PM
tripleblack05's Avatar
tripleblack05
I installed the bypass on my 05 Z51 M6. When you get under the car it is easier to understand. Easy to locate the plug you need to plug into.
Good Luck !!
Old Nov 23, 2014 | 12:46 AM
Dano523's Avatar
Dano523
C6 #10 fuse is singly for the CAGS lock out solenoid in the trans, so instead of having to climb under the car to install the in line resistor at the trans solenoid, you can just change the #10 fuse in the fuse block to a resistor fuse instead (blown smart fuse will work).
http://xse.com/leres/z06/cags.html
It was on the C5 that there was more devices that where being run through the #10 that you have to isolate the resistor down at the Cags solenoid plug on the trans, so just changing out the fuse in the fuse block to a resistor fuse was not a option for these cars.
Bluntly, if you are buying a Cags bypass that requires you to install it at the trans solenoid plug, then you are using the C-5 device on a C-6 car; and wasting a lot of time climbing under the car to do so.
To CAGS Skip Shift Eliminator
