Carbotech Brake Pads
Price XP12 $233 XP10 $183 Less 5% forum pricing.
Pre-bed option add $40.00
Give me a call at 216-780-8825 I will be happy to place an order for you.
Carbotech™ XP10™
When Carbotech™ unleashed the XP10™ to the general public it was an instant success. XP10™ immediately gathered multiple regional, divisional, and national championships. The XP10™ has a very strong initial bite friction material with a coefficient of friction and rotor friendliness unmatched in the industry. Fade resistance is in excess of 1650°F (898°C). Due to the high level of friction and bite, this material is recommended for cars weighing around 2,900lbs or less. XP10™ still maintains the highly praised release, excellent modulation and rotor friendliness that have made all Carbotech™ compounds so successful. Carbotech™ XP10™ is not recommended as a daily-driven street pad due to possible elevated levels of dust and noise.
Carbotech™ XP12™
Another highly successful XP™ series compound with an excellent initial bite, torque and fade resistance over and above the XP10™ compound. XP12™ has temperature range of 250°F to 2000°F+ (121°C to 1093°C+). The XP12™ has that excellent Carbotech release and modulation that has made all other Carbotech compounds so successful. The XP12™ is more rotor aggressive than XP10™, but compared to the competition the XP12™ is still very rotor friendly. XP12™ is NOT recommended for use as a daily driven street pad due to possible elevated levels of dust and noise.
Front $148 Rear $128 Less 5% forum pricing.
The Carbotech™ 1521™ is our high performance street compound. The 1521™ compound is known for its release and modulation, along with unmatched rotor friendliness. 1521™ is also a very low dusting and low noise compound with an excellent initial bite. This compound's excellent linear torque production provides incredible braking force without ABS intervention. Carbotech™ 1521™ operating range starts out at ambient and goes up to 800°F (426°C+). 1521™ is suitable for ALL street cars, perfect for your tow vehicle or fleet vehicle. Carbotech™ 1521™ is NOT recommended for ANY track use.
Give me a call I will be happt to set you up. 216-780-8825
06 coupe z51 6 sp 407 rwhp. BS RE-11 tires with Pfadt specs alignment.
