Jack Lift Point Plates
Old Nov 14, 2012 | 02:16 PM
mongol7112000's Avatar
mongol7112000
Default Jack Lift Point Plates
Hello Forum,
Can anyone give me some solid advise on using and purchasing lift point plates?
I need to remove my rear wheels on my 2005 C6 so I may install my new gran sport style splash guards.
Robert
Old Nov 14, 2012 | 02:23 PM
speedraider's Avatar
speedraider
You can use a little 4 inch piece of a 2x4 under your jacking point , you don't even have to use anything. Just be careful with your floor jack.
Old Nov 15, 2012 | 02:01 PM
mongol7112000
Old Nov 15, 2012 | 02:03 PM
mongol7112000
But won't the wood blocks scratch my paint on the under body.
Old Nov 15, 2012 | 02:24 PM
speedraider
not at the 4 jacking points
Old Nov 15, 2012 | 02:58 PM
EVRose's Avatar
EVRose
If you have a standard floor jack you wont need to use anything. It fits well right where the car is supposed to be lifted without touching the rocker panel.
Old Nov 15, 2012 | 05:21 PM
victorf's Avatar
victorf
^^^OP is already concerned with possibility of wood scratching paint!
Never jack up car directly with floor jack without protections! Common sense, something gotta give! Such as paint and certainly, soft aluminum on cross member will surely suffered dents/distortions!
OP, the following is a few of my ideas:
Prior, along with drive up ramps:
http://i896.photobucket.com/albums/a...6/P1010157.jpg
Now, still still utilize balanced beam with milled protective pads, under contact patch or raising both wheels all at once, directly behind front wheel at jack point. Fit up stage:
http://i896.photobucket.com/albums/a...6/P1010002.jpg
Final stands shows two options, one with additional tire chock for front contact patch and second, spreader bar for under frame rail jacking points use. Set up can be different, dictated by end use:
http://i896.photobucket.com/albums/a...6/P1010005.jpg
http://i896.photobucket.com/albums/a...6/P1010004.jpg
OP, the first photo with the balanced beam will fill your needs safely for sure!
HTHs!
Old Nov 15, 2012 | 05:42 PM
Homer3D's Avatar
Homer3D
I picked up some BMW jacking pucks.
They fit right into these holes.
The clip right in
Old Nov 15, 2012 | 06:38 PM
EVRose's Avatar
EVRose
HTHs!
What you are doing is great. No question. However the car is not so fragile that the steal frame rails are going to bend just from being jacked up at the preferred jack point. As you can see here there is no chance anything painted is going to get scratched and certainly the frame rail is not bending or distorting. I have the plastic jacking pucks also but this is just to illustrate that a jack will fit where it's supposed to go without damaging anything.
Old Nov 15, 2012 | 07:41 PM
speedraider
It took me 6 years to buy jacking pucks....
Old Nov 15, 2012 | 08:13 PM
Biggie G's Avatar
Biggie G
Yea if the frame is gonna bend from my jacking it up without pucks we got a real problem.
I've been jacking her up with a small piece of 2/4 on the pad of my jack.
Old Nov 16, 2012 | 03:25 PM
victorf's Avatar
victorf
Not the question of frame rails being fragile. Rather, for me at least, not to cause any damage including the protective paint on the frame rails. Without protective cushion, it is inevitable frame rails will get scratched by direct floor jack contact. I live in an area where unprotected ferrous material will rust!
As many poster here have shown, concerns and standards on even this simple process of how to jack up the car vary widely! That is to each his own!
I do elevate my car by the frame rails for suspension work, but I choose to do it this way - via the four jacking puck position, with 4 unique custom delrin jacking puck/spreader to compensate for floor elevation:
And doing everything else, this way under contact patch:
Final finished version, front stand with wheel chock:
We all have different skill/knowledge/resource level and confine to perform within our capability. Most members here on the forum falls into the turn key group. Meaning, paid someone to do the work, then come to the forum and bench race!
On the other hand, I belong to the opposite spectrum! And with the additional capability/know how to improve the situation during the process!
Aloha!!
Old Nov 16, 2012 | 05:51 PM
ngtcrlr 007 c6's Avatar
ngtcrlr 007 c6
Aloha!!
Thanks for your expertise...Nice blocks!
Old Nov 16, 2012 | 11:40 PM
waddisme's Avatar
waddisme
You can make your own jacking pads from hockey pucks and an eye bolt for $1.50 ea. Work like a champ - just don't forget to take them off.
Old Nov 17, 2012 | 12:07 AM
Devilish34's Avatar
Devilish34
I use hockey pucks ..cheap and easy to find
Old Nov 17, 2012 | 07:33 AM
speedraider
thats what I ended up with, not so easy to find in florida
Old Nov 17, 2012 | 12:31 PM
ripcord's Avatar
ripcord
AMEN to that, Speedraider! Hockey is an unknown sport down here.
To Jack Lift Point Plates
Old Nov 17, 2012 | 01:03 PM
victorf's Avatar
victorf
Thanks my man!
Another alternative for similar concept with simplicity would be glued stacks of 2x12 wood block with hockey pucks! Unlike cinder block, wood is more resilient and would not crumble into pieces when you least expected!
I choose galvanized steel due to my location and "Steel is for real" as they say! In addition, termite proof!
Old Nov 17, 2012 | 01:20 PM
ripcord's Avatar
ripcord
Is there any problem with twisting the body and possibly cracking something by using just one jack and puck...say to remove just one wheel? Or should two be used to keep the load symmetrical?
Old Nov 17, 2012 | 01:51 PM
EVRose's Avatar
EVRose
These are tough cars and be jacked up like any other. In fact they are so ridgid that you can jack up the front from the side jacking point and not long after the front tire leaves the ground the rear will be off the ground also. Nothing is going to twist or break using one jack. When I was changing my brake pads I did one side at a time like this...
