Vmax Velocity Ring
Old Nov 14, 2012 | 10:16 PM
timd38's Avatar
timd38
Default Vmax Velocity Ring
I was looking at the Vmax Velocity Ring. It make sense to me that the step from a 90MM TB to a 102MM intake is not smooth, so that step could impact performance.
Has anyone tried one?
Thanks!
Old Nov 16, 2012 | 08:11 AM
Justasheet's Avatar
Justasheet
Thanks!
Yep tried it and returned it. Seemed logical to me too. I do know that after installing it, I got all kinds of codes and idle problems. So it will need a retune. I wasn't willing to spend the cash for that.
Jeff
Old Nov 16, 2012 | 09:02 AM
timd38's Avatar
timd38
Jeff
Thanks! I will give it a try with a tune and see what happens. I will let you know.
Old Nov 16, 2012 | 12:39 PM
sallen619's Avatar
sallen619
I have one...never used it because the porting done made it not fit...
I did buy an EconoAid to get the air past the step...it seems to work...it drives smoother down low....
Old Nov 16, 2012 | 01:55 PM
victorf's Avatar
victorf
All those gadgets including spiral machined finish all claims to do this and that to the incoming air and contributes to do this and that to your performance!
Once that "improved" air flow gets passed the throttle body along with "Velocity Ring" and into the cavity of the IM, with all those formed snorkels that feed air into each of the combustion chamber. This scenario tells me that, whatever characteristic of the air flow will be neutralized/negated by the sheer designed nature of uneven shapes and large volume within the IM internal. In other words, that previous "improved" air simply becomes an air mass, dwelling within the IM cavern, available for the intake vacuum!
However, if such air flows directly into just one cavity without interruptions, there is certain benefit. Such as "porting" IM runner with intake port, which offers an direct and immediate benefit!
Opinion from one skeptic!
Old Nov 16, 2012 | 02:52 PM
Justasheet's Avatar
Justasheet
Victorf, I am in agreement with you. I would like to see some performance data of the NW 102mm TB with the Fast 102 intake. I haven't heard much about it. I think if anything would work better, that would be the way to go.
Jeff
Old Nov 16, 2012 | 05:52 PM
timd38's Avatar
timd38
Jeff
My guy in Detroit agrees with both of you. On a engine dyno, a stock throttle body is good to 1,000 HP. He hasn't tried the VMAX ring, but the theory passes the smell test.
Old Nov 16, 2012 | 08:01 PM
sallen619's Avatar
sallen619
Jeff
I think CMS did some dyno results on this...I'd have to search for the thread.
Old Nov 16, 2012 | 09:13 PM
sallen619's Avatar
sallen619
http://forums.corvetteforum.com/c6-s...2-comparo.html
Old Nov 17, 2012 | 02:15 PM
victorf's Avatar
victorf
Large volume certainly offers benefit. As in forced injection - principle of packing in larger air volume at an given space along with adjusted fuel to compensate. That is a formula historically proven!
But transitional step taper? Such as a machined short taper ring, starts from an given 90/92mm opening at one end and the opposite end with machined taper to 102mm? What does it do to provide, in terms of volume change? Isn't it still a 90/92mm opening?
Another reason being a skeptic!
Unless available facts convinced me otherwise, right now, I regard it along with spiral machined finish, Sham-Wow and Tornado!
Old Nov 17, 2012 | 07:57 PM
timd38's Avatar
timd38
I agree with what you said. The reason I think the thing works is becasue it takes the step out of the air going into the engine.
I am going to see if I my guy in Michigan is building any engines with FAST 102 intakes and will send him the ring to see if makes any difference on the dyno.
Old Nov 17, 2012 | 08:19 PM
sallen619's Avatar
sallen619
The reason for the ring is some people were experiencing problems at low rpms. The ring is supposed to stop the air from stalling at that "step" when the velocity of the air flow is lower.
Its a drivability product...no need to group it with the sham-wow/tornado...
Old Nov 18, 2012 | 12:54 PM
victorf's Avatar
victorf
Terrific, as they say - Proof is in the pudding! Maker had posted some claims before. Interesting if the guy in Michigan will be thorough and unbiased in the dyno! Is the guy in Michigan creditable/reputable? Otherwise, everything then falls under hearsays!
Thanks for staying curious and taking the extra effort to find truth!
Product producers always make this and that claims to sell their products! They are betting on making a million, if a million people will buy into their $1 product! I'd read the claims on this ring when it first came into the market.
Unless it is something like "without a doubt" - the drastic SOTP feel of after headers installation without even dyno, claims of 5 hp on dyno gains could be just time of day thing. And some after the install and say "Yea, a lot smoother", well, who are these guys!
Right now remaining a skeptic on the products I'v mentioned!
Old Nov 18, 2012 | 09:17 PM
C6-13thPilotCar's Avatar
C6-13thPilotCar
Thanks!
I changed from a stock ported manifold to a Tony Mano ported FAST 102 with the 90mm TB and velocity ring.
With a re tune rwhp went from 645 to 721 rwhp and 655 rwtq. When I had a FAST 90 on this engine it only has 665 RWHP. Fast 102 and v ring will make a difference as long as you get a GOOD tune done when you are done.
See Sig for mods.
To Vmax Velocity Ring
