2005 power steering pump pulley removal
Old Nov 15, 2012 | 04:43 PM
snoopdan's Avatar
snoopdan
Default 2005 power steering pump pulley removal
How do I get this thing off? lol, the ABS looks like its in the way...do I just start taking stuff off until everythings out of the way? aahhhhh
Old Nov 16, 2012 | 08:07 AM
Justasheet's Avatar
Justasheet
I read a few posts on here to know that there is one bolt that takes forever to get out because of clearance issues. I believe some have elongated the hole in the bracket to an oval after removing the bolt so that future removals are easier by allowing the pump to move.
Look at some posts where a cam swap took place for instructions.
Jeff
Old Nov 16, 2012 | 02:45 PM
snoopdan's Avatar
snoopdan
hmmm ok, i've also looked around and found that someone took off the power steering resivior to get access to the bolts that hold the pump on and just pull the power steering pump off alltogether...can anyone confirm?
Old Nov 16, 2012 | 03:54 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Its a serious pain to remove. I took off the reservoir to access the bolts and while it was off I made the bolt holes into slots to make it easier next time around.
Old Nov 16, 2012 | 04:01 PM
Justasheet's Avatar
Justasheet
I knew that I had read that somewhere. Pretty ingenious.
Old Nov 23, 2012 | 09:21 AM
05C6GAC's Avatar
05C6GAC
Any one have futher info on this ans I'm getting ready to tackle this also??? Does the pulley have to come off first??? If so what needs to be removed to gain access??
Thanks!!!
Old Nov 23, 2012 | 01:19 PM
victorf's Avatar
victorf
When you slot the holes, curious as to the direction - up, down, left or right? All the holes? Straight slot or radial? Using machine or rat tail?
Please elaborate!
Old Nov 23, 2012 | 10:32 PM
gotjuice?'s Avatar
gotjuice?
St. Jude Donor '13
I remove the 4 bolts that hold the bracket assy. to the head with a wrench. It helps to have the water pump removed first. Then you can remove the pulley it needed.
Old Nov 23, 2012 | 11:10 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
Go to autozone and rent/borrow the pulley puller.. It's better than a cramp from one flatting the hidden bolt!!
Old Nov 26, 2012 | 04:39 PM
snoopdan's Avatar
snoopdan
ended up wussin' out and took it to a mechanic.
Old Nov 30, 2012 | 01:32 PM
05C6GAC's Avatar
05C6GAC
Please elaborate!
Old Nov 30, 2012 | 01:39 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Originally Posted by 05C6GAC
I will take some pics and post them, since my bracket is off, but I probably cant get to the shop untiil monday....
Old Dec 2, 2012 | 06:03 PM
05C6GAC's Avatar
05C6GAC
Thanks geting ready to start this project next week, I just received a replacement from Turn One last week!!!
Old Dec 3, 2012 | 07:03 PM
05C6GAC's Avatar
05C6GAC
Old Dec 3, 2012 | 07:13 PM
majorpayne317641's Avatar
majorpayne317641
I know there is an easy trick to removing the rack and pinion, this might clear out some room to get to the pulley? I'd imagine you might be lucky if you can remove the pulley without the radiator out of the way if your using a long puller.
To take the rack and pinion off, jack up the frame, loosen the front subframe bolts, unbolt the tierods, then unbolt the rack, use a screw driver to pry the subframe down a little more, and you can slip the rack out through the side of the wheel well.
Old Dec 4, 2012 | 08:38 PM
05C6GAC's Avatar
05C6GAC
Well it wasn't easy, and the parts that should have been easier weren't, but I got it changed from the top this morning. Went back together a lot easier than it came appart, except for the parts that should have been easier and werent!!!
To 2005 power steering pump pulley removal
