How to apply proper torque?
Old Nov 19, 2012 | 06:47 PM
vettenutchas's Avatar
vettenutchas
Default How to apply proper torque?
Does any one know how to tighten the nut holding the rear lower A arm ball joint to the upright spindle to the proper setting? Because the half shaft is directly above the ball joint there is no room to put a socket on the nut and use a torque wrench to tighten it to the proper setting. Only an open ended wrench can be used on the nut, not even enough room to slip a box wrench on the nut. Any info would be GREATLY appreciated!!!
