A6 transmission lines
Old Nov 22, 2012 | 05:12 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
Default A6 transmission lines
Does anyone make an adaptor or fitting to run AN fittings directly into the 6L80 trans. I want to run new lines and would rather not splice into the existing ones
Old Nov 22, 2012 | 08:58 PM
Redrocket1045's Avatar
Redrocket1045
Nope. You're gonna need to TIG weld your own.
Old Nov 22, 2012 | 10:20 PM
realcanuk's Avatar
realcanuk
St. Jude Donor '13
That sucks !
Old Nov 23, 2012 | 12:04 AM
HOXXOH's Avatar
HOXXOH
I made one in an attempt to try a rear mounted cooler. The cooler location didn't work, but the adapter did.
PM me if you're still interested.
Old Dec 12, 2012 | 04:03 PM
mrgillies's Avatar
mrgillies
Hey Tom (HOXXOH)
After doing ProAutosports at Firebird last weekend it my A6 went to Overtemp and engine would only run at idle. I'm looking to install an aftermarket Transmission cooler so reduce the chance of this happening again
I seem to remember you put one horizontally in front of the radiator, I'm looking to do something similar, especially since I have the Eforce, its intercooler is already taking up some real estate.
Where did you get the parts especially the fittings to have this cooler run in series with existing cooler?
Steve
Old Dec 12, 2012 | 06:09 PM
carlrx7's Avatar
carlrx7
St. Jude Donor '08-'09
why do you need to make new lines?
Old Dec 12, 2012 | 06:23 PM
mrgillies's Avatar
mrgillies
For the additional cooler
Old Dec 13, 2012 | 01:24 AM
HOXXOH's Avatar
HOXXOH
Originally Posted by mrgillies
Hey Tom (HOXXOH)
Steve
No fittings needed, only guts. It's independent and I slipped 3/8" tubing over the OEM tubing ends and used double hose clamps.
I'm thinking of going to series, because I have a real hard time getting the temps above 140* at the drags and I've already blocked off half of the cooler fins.
To A6 transmission lines
