Ls3 Heads/Cam record results
Old Nov 23, 2012 | 11:29 AM
robz's Avatar
robz
Default Ls3 Heads/Cam record results
We recently beat the Ls3 heads/Cam record with a mild street package that was designed for a future Procharger.
Congrats to Matt (Tune Time) and Gary for running a 10.37 and 134+ mph.
Mast heads
Custom Cam
4.10 gears
American Racing Headers
RPS Clutch
After thinking it over and seeing the results of some of the ls3 headed cars we've done, we feel confident that we can match, if not exceed, the performance above with our ported stock LS3 heads and cam package.
And maintain great driveability. I can get more detals if people are interested.
If there was an interest in an all out max effort combo for those who are focussed on ET drag strip results we could make that happen too. With the right driver we're looking at 9 something and near 140mph in great air.
Old Nov 23, 2012 | 11:45 AM
SpinMonster's Avatar
SpinMonster
Results are more likely from not using LS3 heads.
Trick flow powers the fastest LS2 C6's but no one wants to use them on the LS3.
Old Nov 23, 2012 | 04:49 PM
dennis50nj's Avatar
dennis50nj
not anymore, 10.15 LS3 HEADS ON AN LS2
Old Nov 23, 2012 | 05:33 PM
timd38's Avatar
timd38
LSA heads are less expensive and stronger than LS3.
Just food for thought.
Old Nov 23, 2012 | 05:43 PM
robz's Avatar
robz
We're talking about n/a streetcars that can run mid-low 10's and drive anywhere.
Alot cheaper, easier, and much less wait. Plus the stock valvetrain can be used in most cases.
Old Nov 23, 2012 | 06:45 PM
Devilish34's Avatar
Devilish34
stronger for boosted applications but have heard of LSA head guys swapping to LS3 heads and picking up power ....
Old Nov 23, 2012 | 06:49 PM
jbsblownc5's Avatar
jbsblownc5
2017 C5 of the Year Finalist
St. Jude Donor '08
Congrats on the new times!!!
Old Nov 23, 2012 | 06:57 PM
timd38's Avatar
timd38
Great times for an LS2 with LS3 heads and cam.
LSA heads use the same parts and have the save ports as LS3, just stronger and lower priced.
Old Nov 23, 2012 | 07:20 PM
SpinMonster
Awesome! I found a link. Figures its another automatic! Did you help sprinkle some magic on it?
Old Nov 23, 2012 | 07:21 PM
SpinMonster
Stronger meaning materials?
Mast heads are 3/4 inch decks.
Old Nov 23, 2012 | 08:34 PM
dennis50nj's Avatar
dennis50nj
I wish i did Guy, so i could sprinkle some on mine
Old Nov 23, 2012 | 08:47 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
To set the record straight, my LS3 heads from SDPC are actually LSA cores that they start with. I wasn't aware of this until I tried to bolt my stock LS3 intake on and the dowels pegs didn't line up. After almost 2 hours on the phone with scoggins we figured it out. If others are picking up power by switching from lsa to ls3 heads then I feel cheated..lol just kidding.
To say that max power can't be made with ls3 heads can't be completely accurate. I ran over 105mph in the 1/8 with a completely stock bottom ls2 and over 131.5 mph in the quarter with only 3.42 gears. That was done with a stock LS3 intake that I ported in my garage in little over an hour. Point being that with professional parts I might have went quicker. My cam is not terribly big but is decent size. Also I'm running stock rockers.
Congrats on that run Matt, Gary and Rob.. There's more in it!
Old Nov 23, 2012 | 09:15 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
I don't remember, what was the fix for that issue?
Old Nov 23, 2012 | 09:20 PM
stanger383's Avatar
stanger383
St. Jude Donor '09
I grinded them off and had to rely on the bolts.
I talked with SDPC in person at the Indy US nationals and they said nobody had ever called with that complaint
Old Nov 23, 2012 | 09:24 PM
JUIC3D's Avatar
JUIC3D
Hmm, that's odd. Very odd. It's obviously working for you though.
Old Nov 23, 2012 | 09:43 PM
LS1LT1's Avatar
LS1LT1
Congrats again Rob, Gary, Matt and the owner of the car as well (don't know his screen name or if he's even on here).
I'll say! LOL
In fact, based on stanger383's results it might even offer a total ADVANTAGE! LOL
Old Nov 24, 2012 | 01:14 AM
SpinMonster
OK so I'm back to my original opinion of aftermarket Vs ported LS3 stockers.
Thanks for sharing your complete build info. Its rare to have people share like that.
To Ls3 Heads/Cam record results
Old Nov 24, 2012 | 09:50 AM
GARY2004Z06's Avatar
GARY2004Z06
I guess we have to take some stock LS3 heads, port them, and have them run low to mid 10s in streetable combination.
Rob- It's becoming quite arduous to do what we say we can do. (again)
Old Nov 24, 2012 | 09:55 AM
robz's Avatar
robz
We've seen the ls3 heads make big power with an experienced head porter and a few different cams. As these performance packages make it to the street the numbers will trickle in and I already know the possibilities.
Old Nov 24, 2012 | 10:11 AM
robz's Avatar
robz
I agree, we're not guessing here and after seeing/comparing the dyno results I'm even more confident.
If we took a beefy mast head and ported it to its ultimate limit with a professional who specializes in drag racing then I have no doubt we could make more power with the aftermarket product provided we utilize all of the flow and other characteristics of the head to our advatange with rpm and other things.
But lets face it, the driveability will suffer immensely and you are looking at maybe $6000 + just for the heads and port work and that can take up to 6 months of time.
I'm saying it makes sense to take your existing heads that you know will fit perfectly and upgrade them because we are now confident that they make big power without a big loss in driveability.
Or swap your your ls2 heads for ls3 and see huge gains. Take advantage of other peoples R&D that have proven results and utilize as many gm parts as possible to save money, and you know they already work and fit. I bet it would be difficult to find someone who knows more than I do about the frustrations of aftermarket parts on these late model vettes.
