A&A Pulley
Old Nov 26, 2012 | 06:12 PM
donb1226's Avatar
donb1226
Default A&A Pulley
2008 c6 do i have to remove supercharger to change A&A pulley from 3.8 to 3.6. or is there a way to do it on the car
Old Nov 27, 2012 | 07:10 PM
mourat's Avatar
mourat
If you have a portable impact gun then move the blower off to side, impact the nut off, take a heat gun, heat the pulley up with the heat gun, DO NO USE TORCH!
once its nice and toasty (just pulley) since the pulley is aluminum and shaft is steel, the expansion rate is vastly different, then lightly pry on pulley and it will pop off.
Hope that helps.
