Oil Cooler question
Old Nov 27, 2012 | 11:44 PM
schizcat's Avatar
schizcat
Default Oil Cooler question
I have an 05 Z51 M6 with the internal oil cooler. I am wondering if the oil cooler is needed and how much of a difference it would make on a daily driven street car. Reason I am asking is that I have to swap my radiator and have access to a non-EOC radiator. I would have to eliminate the internal oil cooler and maybe swap to an external oil cooler in the future. Thanks for the info.
Old Nov 28, 2012 | 05:20 AM
taken19's Avatar
taken19
Track Junky
For street driving, you won't see a significant difference. Remember that non Z-51 cars don't have one... On the track will be a whole different story!
Old Nov 28, 2012 | 09:06 AM
schizcat's Avatar
schizcat
Thanks. Thats what I thought. Do you happen to know how to plug the line holes on the oil pan after removing the lines?
Old Nov 28, 2012 | 10:39 AM
ErnieN85's Avatar
ErnieN85
you can't plug them. it (base car) comes with a small cover & gasket to alow the oil out one hole and into the other
Old Nov 28, 2012 | 12:03 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
The radiator setup is nice, it cools the oil when it gets hot; and warms the oil when it's cold.
I would try hard to retain it.
Old Dec 1, 2012 | 06:26 AM
rob@thinkauto's Avatar
rob@thinkauto
1st Gear
Default Do we need oil coolers?
You should regard an oil cooler on a street driven vehicle as insurance. It is there for a worse case scenario e.g. It is high ambient temperature, you are driving up a steep incline, you are in a low gear and using a lot of rpm. The oil is getting very hot and losing viscosity and therefore film strength eventually the film strength is not enough to avoid bearings making metal to metal contact. You are then in deep trouble.
If you go the external cooler route try www.batinc.net,
To Oil Cooler question
