Can I get away with
Old Dec 7, 2012 | 11:22 PM
Underratedneverfaded's Avatar
Default Can I get away with
Can I get away with running 305/35/19 on my base without throwing codes or messing with the active handling systems? I can get a good deal on some Mickey Thomas street radials and wanna be sure before I buy.
Old Dec 7, 2012 | 11:32 PM
taken19's Avatar
taken19
Track Junky
As long as the rear tire diameter is about 1.2" larger than the fronts you will be ok. Take a look at the different tire diameter ratios before you buy.
265/35 wide fronts and 305/30 wide rears are just about the right target. They will both fit in stock C6 rims as well.
Old Dec 8, 2012 | 07:26 AM
timd38's Avatar
timd38
I have them on my car with no issues.
Correction 305/30 19"
sorry
Old Dec 8, 2012 | 07:28 AM
jpee's Avatar
jpee
I'm using 305/35x18" on my car (Drag Radials) and never get a code.. however with 19" you should check your "overall" diameter and be sure its close to the OEM tires..
To Can I get away with
