Rear Exhaust Hanger Replacement
My rear exhaust hanger was stripped by a shop. This is the bolt that screws into the hanger that goes into the impact bar in the rear of the car.
Is the hanger attached to a captive nut welded into the impact bar? If so I can just use a helicoil to fix it, or is it like the C5, with the bar with an attached nut that once the hanger is removed, the bar will fall down and be almost impossible to fix without removing the rear fascia?
Any tips on fixing it? The shop had just tack welded the hanger.
Thanks!
