Questions on deleting Diff Cooler from ZR1 Diff!
Old Dec 17, 2012 | 11:06 AM
Shoaf85's Avatar
Shoaf85
Default Questions on deleting Diff Cooler from ZR1 Diff!
I have been searching around the forum a little and havent ran across any info on this yet! I am installing a ZR1 torque tube/tranny/diff in my 07 and I want to delete the diff cooler. I am wondering if anyone can give me some tips on what I need to pull this off as far as plugs for trans lines and so on!
Stephen
Old Dec 17, 2012 | 02:15 PM
Jeremy@RPMTransmissions's Avatar
0Jeremy@RPMTransmissions
Former Vendor
Stephen,
Is your 07 a Z51 equipped car?
Old Dec 17, 2012 | 02:16 PM
Shoaf85's Avatar
Shoaf85
Non z51
Old Dec 17, 2012 | 02:29 PM
Former Vendor
Ok. Being a non-Z51 car you will need to build a loop line to run from the outlet of the pump on the front passenger side of the transmissions, over the top of the trans and back into the return port on the driver side of the trans. You will need to put a small notch in the passenger side of your torque tube bell housing where the trans meets, for the cooler line to exit.
Once you take care of the trans pump then you can work on deleting the differential pump. You will need a blank C5 or C6 base model differential rear cover and gasket. You can use the drain plug from your differential to plug the rear cooler line hole and you will need a 14mm x 1.5 o-ring style plug for the hole in the driver side cover.
Hope this helps get you rolling. Let me know if you have any more questions.
Jeremy
Old Dec 17, 2012 | 02:32 PM
timd38's Avatar
timd38
I want a cooler on my 2006 Z51, is there a way I can buy his and put it on mine?
Old Dec 17, 2012 | 02:40 PM
Former Vendor
Originally Posted by timd38
I won't a cooler on my 2006 Z51, is there a way I can buy his and put it on mine?
To put a cooler on a non-diff cooler car you will have to machine the pinion gear. That is the biggest task. We can do that for you for $150.00 + shipping. Then you will have to cut and lengthen your return line so it reaches the heat exchanger. Then you will need to purchase the cooler line from the heat exchanger to the return port on the driver side of the transmission. You will need to purchase the line for an 06-08 Z06 because the return location changed in 2009.
Old Dec 17, 2012 | 02:50 PM
Shoaf85's Avatar
Shoaf85
Thanks for the info Jeremy, I am actually awaiting a phone call back from TJ with a price for all the parts from you guys
Btw I received the entire bellhousing along with the zr1 TT so I think the provision for the cooler line is already there!
Old Dec 17, 2012 | 02:58 PM
Former Vendor
I will PM you with some prices.
Did you get the shifter linkage rod from the ZR1 as well? in 09-13 GM shortend the entire torque tube and shifter linkage rod.
Old Dec 17, 2012 | 03:01 PM
Shoaf85's Avatar
Shoaf85
No I didn't get the linkage
Old Dec 17, 2012 | 03:08 PM
Former Vendor
To use the ZR1 torque tube you will need that shorter shifter linkage rod. Any 09+ rod will work.
I just PM'd you with the loop line and diff conversion kit.
Jeremy
Old Dec 17, 2012 | 03:46 PM
Joe_G's Avatar
Joe_G
St. Jude Donor '08
Great info RPM.
Shoaf if there is any way to keep the cooler I would do it if I was you.
I have a diff temp gauge in my car and in normal highway driving it gets up to 250. When I used to road course the diff temp would be the thing that would get me off the track. My factory oil cooler and trans cooler kept things in check but the diff got hot, 280+, in 20 minutes. I do have 4.10 gears so that might have affected things.
My point is, a diff cooler is a very beneficial thing if there's any way to keep it in your car. I wish I had one.
p.s. that diff drain plug is an oddball size and not easy to get. I found that Ecklers sells a magnetic drain plug which I drilled out and tapped for the temp sending unit, in case anyone is interested. Plus, use an oil temp gauge as they go up to 300 vs. 270 for water gauges if you decide to put in a gauge. I have one gauge with a toggle for trans temp or diff temp.
Old Dec 17, 2012 | 04:01 PM
Shoaf85's Avatar
Shoaf85
I would really like to use the zr1 tube....what type of modification will be required to the cradle?
Old Dec 18, 2012 | 10:17 AM
Former Vendor
To use the shorter ZR1 cradle you will need to elongate all 4 mounting holes in the cradle. They need to be slotted towards the front of the car roughly 5/8". Another option is to purchase an 09+ rear cradle. I do have a late shifter rod. I will go through them and find it this afternoon and let you know how much it will be.
Old Dec 18, 2012 | 10:24 AM
Shoaf85's Avatar
Shoaf85
Ok sounds good thanks!
Im sure that you already know but the diff mounting holes in the cradle are slotted to allow for slight adjustment front to rear it seems, is this not enough or will I still need to elongate the holes more?
Old Dec 18, 2012 | 10:35 AM
Former Vendor
Yes they will need to be slotted quite a bit more towards the front. The best way to judge how much would be to install the torque tube, trans and differential into the car with the mounts installed on the differential. Place the cradle into the car and tighten the mounting bolts. Then lower the differential down onto the cradle till the mount studs touch the cradle and mark their position. Then clearance the mounting holes accordingly.
Old Dec 18, 2012 | 10:46 AM
Shoaf85's Avatar
Shoaf85
Thank you sir
Old Dec 18, 2012 | 07:43 PM
JUIC3D's Avatar
JUIC3D
St. Jude Donor '11-'12-'13-'14
Awesome info in here
To Questions on deleting Diff Cooler from ZR1 Diff!
Old Dec 18, 2012 | 11:26 PM
marine&hisvette's Avatar
marine&hisvette
Subscribed
Old Dec 19, 2012 | 07:29 PM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
Here's some pics of a 2009 Z06 I did some work on last week
1. Removed/replaced trans (bent shift rod/internal trans) trans shop stated this was a problem with Tremec, was a NE shop that did the repair under warr.
2. Replaced the trans harness, the GM dealer wasn't too focused on proper routing(trans was replaced prior), the LHS harness was resting on the muffler pipe causing a Left Rear Wheel TCS code
3. 2009 Torque Tube measured in at 55"
Pics of the lower and more forward trans return location(2009 up), the 2009up cradle and the damaged harness; aligned the car before the hour drive back to the CT shoreline
Old Dec 19, 2012 | 07:36 PM
timd38's Avatar
timd38
Why 2009 torque tubes shorter?
Just curios.
