Headers only on LS3?
Old Jan 3, 2013 | 11:33 PM
bud miller's Avatar
bud miller
other short vid..outside car...ls3,z06 exhaust with npp factory mufflers...........
Old Nov 20, 2016 | 02:26 PM
Z51LS3's Avatar
Z51LS3
I know its an old thread but incase others are researching, I had the same concern.
I went with 1 3/4 long tubes and high flow 3"x2.5" catted X pipe hooked to the stock 2.5" over the axle npp exhaust with stock npp mufflers. When driving normally the sound level is basically the same as stock, but you will notice the 'header sound effect' which is sort of tinny swooshy like sound like what your plumbing in the walls of your house sounds like while the water is running, almost sounds like its leaking even when its not. Also the tone is a bit different slightly less 'tuned sounding' under part throttle and when you floor it WOT with NPP it really screams and is a completely different sound, very high pitched in comparison!!
If you want close to the same gains without sound sacrifice then go with a Z06 headers & system and from what i read you would get about 60-70% performance of LT system. One guy reported 3MPH gain in the 1/4 mile with swapping to Z06 exhaust only.
I gained 6-7MPH with my exhaust, KB intake, ported TB, ele. water pump and ECS tune.
Old Nov 20, 2016 | 03:08 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by JUIC3D
Catbacks are generally worth 0hp and only change the sound of the vehicle. You won't be leaving anything on the table.
I've seen claims from vendors on this site of their catback adding 10hp but never any proof to back it up.
GM says the NPP dual mode exhaust adds 6 hp, SAE certified. So a catback system can add something, but whether it makes a discernable difference besides the noise, is another story.
